    Rayscaper New Releases
    rayscaperrender
    785 Posts 14 Posters 363.3k Views 15 Watching
    • KrassK
      Krass
      Hello,
      another test where I changed the lights and set the gaussian filtering mode (radius 1.2 px) to, like antialias, correct the material problems.
      I like the result, but I'd have to add some artificial lights to illuminate the scene.
      https://jskup.fr/wp-content/uploads/2025/02/gaussian-1.2-denoise-denoise.png
      Krass
      • KrassK
        Krass
        I also applied a light coat of denoiser
        Krass
        • KrassK
          Krass
          By external denoiser I mean I use a program dedicated to denoising
          Krass
          • KrassK
            Krass
            an other render, this time I used Rascaper denoiser option
            https://jskup.fr/wp-content/uploads/2025/02/filter-box-plus-RSCaper-denoiser.png
            Krass
            • KrassK
              Krass
              with rayscaper denoiser on
              Krass
              • pixelcruncherP
                @Krass I like the result.
                FYI, Rayscaper uses Intel's OpenImageDenoise (link). I think this is the same denoiser that Twilight Render uses in its denoise extension, so you should see comparable results.
                • KrassK
                  Krass
                  final high res render, reduced in 1080 p and an other render, exterior
                  https://jskup.fr/wp-content/uploads/2025/02/rayscaper-1080p.jpg
                  https://jskup.fr/wp-content/uploads/2025/02/final2.jpg
                  Krass
                  KrassK 1 Reply Last reply
                  Reply Quote 2
                  • KrassK
                    Krass @Krass
                    I'm getting used to this little program
                    https://jskup.fr/wp-content/uploads/2025/02/2denoised.jpg
                    https://jskup.fr/wp-content/uploads/2025/02/4denoised.jpg
                    Krass
                    Reply Quote 2
                    • pixelcruncherP
                      Nice renders, especially the last one with the dinner plates.Nice use of DOF.
                      S 1 Reply Last reply
                        sashapepperspray @pixelcruncher
                        @pixelcruncher Hello, I have downloaded sketchup 2025 and rayscaper doesn't work, it just says idle and doesn't render, (and do you have plans to incorporate sketchup's pbr materials into rayscaper's materials?) thanks
                          Thomas was is aware of the incompatibility with 2025.
                          • pixelcruncherP
                            Hey, Rayscaper users!
                            Another release!
                            Rayscaper 0.9.44 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
                            What Changed?
                            • Added support for SketchUp 2025.
                            • Fixed energy loss in glass materials, which previously caused them to appear too dark.
                            • Made asset thumbnail size configurable via the settings dialog.
                            • Fixed reloading of SketchUp materials in Rayscaper.
                            • Fixed light emission issues with HDRI environments.
                            • Removed the 1000Γ—1000 pixel resolution limit for the free version.
                            The asset thumbnail size is configured via the settings dialog:
                            Help me build the community πŸ‘
                            If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
                            Happy Rendering!
                            • pixelcruncherP
                              pixelcruncher Extension Creator @sashapepperspray
                              @sashapepperspray said in Rayscaper New Releases:
                              SketchUp 2025 is now supported in version 0.9.44 Beta. Let me know if there are any issues.
                              I plan to map SketchUp's PBR material to Rayscaper's PBR material in one of the upcoming releases.
                              Cheers,
                              Thomas
                                @pixelcruncher Thanks, it works
                                • KrassK
                                  Krass
                                  Hello, Pixelcruncher,
                                  I updated the rbz from sketchucation, but I don't have this option to choose the thumbnail size.(very good improvement)
                                  But I didn't uninstall rayscaper before reinstalling,
                                  Krass
                                  • KrassK
                                    Krass
                                    that's fine, but I had to delete the rayscaper files in the hidden folders and in the sketchup plugins too. that's great, it'll let me look at the texture previews in detail on my laptop...., which has a high-definition screen, and I needed a magnifying glass...
                                    Krass
                                    • KrassK
                                      Krass
                                      and thank you for removing the pixel resolution limitation
                                      Krass
                                      • pixelcruncherP
                                        @Krass said in Rayscaper New Releases:
                                        Hey @Krass ,
                                        Can you check the version you are running?
                                        If it's 0.9.44 or higher, you should be able to configure the thumbnails via the settings dialog:
                                        After updating the plugin in SketchUp, a restart of SketchUp is required. Otherwise, you will continue to run the older version of Rayscaper.
                                        Regards,
                                        Thomas
                                        • KrassK
                                          Krass
                                          Hello, thomas,
                                          sorry for the late reply
                                          I will try to answer tonight
                                          Krass
                                          • KrassK
                                            Krass @Krass
                                            rays.png ![@Krass](image url)
                                            I've stopped rendering for now, I'm stuck with this problematic project that I sent you screenshots of. These spots in the shadows
                                            Krass
                                            pixelcruncherP 2 Replies Last reply
                                            • 39
                                            • 40
                                            • 5 / 40
