    Quick Comparison -Subd and Artisan
    renderpluginsextensions
    39 Posts 18 Posters 31.3k Views 18 Watching
    • cottyC
      cotty
      @cuttingedge said:
      Thanks for this, I didnt know that both soft-ness and smooth-ness of the geometry has influence over the quality of the subdivisions.
      SubD (catmull clark subdivision) works best for quads, and quads in SU are quasi-defined by Thomthom this way "two triangles share an edge that is soft+smooth and doesn't cast shadows".
      Artisan uses another subdivision algorithm and don't need quads.
      my SketchUp gallery
      • cottyC
        cotty
        my SketchUp gallery
        • W
          Whaat
          @cuttingedge said:
          plus it retains the material and UV info (haven’t fully tried this though). You will lose all materials in artisan once subdivided.
          Just want to clarify a common misconception about Artisan. You CAN retain materials and UVs in Artisan, you just need to enable that feature in 'Settings'. It is not enabled by default because it results in a performance hit.
          • henyaoiH
            henyaoi
            Hi, everybody. Here's my example with Artisan, texture and UV is retained.
            SketchUp Service and Tutoring http://monoloki.com
            • alvisA
              alvis
              OK. This is my little experience after several hours. Excellent tool. Sorry for the last image
                Physically plausible
                Sent from my iPhone using Tapatalk
                • alvisA
                  alvis
                  • pbacotP
                    One grand pig! Very fat. Reminds me, I think something from my childhood. A piggy bank that wagged its tail up and down when the coin was put in.
                    • alvisA
                      alvis
                      I had to post to another thread. SUbD examples and models.
                        Love that pig! 😄
                        • HornOxxH
                          HornOxx
                          Hi, as shown below, I´ve never managed to keep any texture by using Artisan.
                          What is the trick to achieve your result?
                          never trust a skinny cook
                          • cottyC
                            cotty
                            my SketchUp gallery
                            • HornOxxH
                              HornOxx
                              ... and once again AUAAA 😲 thanks Cotty! I am ashamed 😉
                              How could I have overlooked this option?!?!?
                              • dereiD
                                derei
                                I think the Coca Cola has the texture distorted... and I am sure is not because of the brand. Pepsi seems fine.
                                What would be the cause?
                                DESIGNER AND ARTIST DEREI.UK
                                  @yorik1984 said:
                                  I think "Coca" and "Pepsi" are same. How do you think?
                                  Love it! 😄
                                  Would you mind sharing the model? I'm about to look into OpenSubdiv and it might provide some better UV mapping features. That model looks like a nice test model to experiment on.
                                  • yorik1984Y
                                    yorik1984
                                    I make a small test inspired by correspondence on Skype.
                                    Not for holy wars just for fun.
                                    [3dwh:jhj44tuk]ue4128cb4-6aa0-4d0b-b03d-ea9f1ff71cc0[/3dwh:jhj44tuk]
                                    • yorik1984Y
                                      yorik1984
                                      Add link to warehouse in post
                                      • H
                                        hsrhdrehre5654654
                                        Also, in my case, i need to use Artisan instead of SubD because with SubD i keep getting invisible "edges touching more than two faces" and it wont let me to subd.
                                        With Artisan, smooth as hell. So i will say that Artisan is more flexible when dealing with geometry. I just needed to discard subd because it was making me to waste even more time, instead of the opposite.. 😛
                                          Got an example model to share?
                                          • H
                                            hsrhdrehre5654654
                                            Unfortunately i dont have the model, since i started from scratch again , using Artisan. But i asure you that the cuts were pretty clean (i made sure of it) with no edges between and weird things, and still i was getting that error.
                                            • 2 / 2
