    Get Link for Official Sketchup Bug Reporting
    28 Posts 14 Posters 9.2k Views 14 Watching
    • N Offline
      Nentautako
      [/quote]
      What has this got to do with the topic here?
      I smell a sleeper πŸ˜’[/quote]
      sorry then, i think this newby doesn't know what's he's talking about. kindly just erase my post.. 😳
      • V Offline
        victor hugo
        Hello..
        For some odd reason I can't start SKU, not new file not even a small file already created when the software is loading it freezes for a while then the sketchup BSOD (BUG SPLAT OFF DEAD) screen shows.
        Is there a solutions for this?
        Gracias.
          What SketchUp version?
          What OS?
          Did it work before?
          Have you tried reinstalling?
          BSOD indicate hardware/driver error. Have you updated your computer's drivers? (Especially the graphic card?)
          What graphic card do you have?
          (Btw - it's better if you create a new topic when you have a question that's new for the topic.)
          • V Offline
            victor hugo
            SKUP Version 8.0.15158
            OS Win XP SP3
            Yes It was working before, I also was getting the "Failed to create empty document" when I was trying to open other session, I think Gaeius had some issue also with the "Failed ....document" thing.
            I will haven't tried reinstalling yet, Which folders do I need to back up if any?
            BSOD I had those as "Blue Screen Of Dead" on other computers for the Windows Driver's, I've just found that it also fits the Bug Splat, video card is updated.
            Video Card NVIDIA Quadro FX550
            Thanks thomthom for your quick response.
            • V Offline
              victor hugo
              Is it possible that this "error/problem" is generated by the Fredo tools update or the updated website, because when I try to update the plugin I get the attached error.
              Thanks.
                No - Fredo plugins doesn't create BSODs. I'm still betting it's a hardware/driver issue - it always is.
                • V Offline
                  victor hugo
                  I reinstalled the program and updated the drivers, I've also tried loggin in a using a different user. On the different user I can open multiple sessions but when I go back to my regular user and when I try to open other sessiont it says "Failed to create empty document", this is when I'm lucky to even have on session open.
                  Don't know what to do now, is there a solution for this issue.
                  Thanks.
                  • ely862meE Offline
                    ely862me
                    πŸ˜† I think people take the thread's title as granted !
                    Perhaps changing the title will help not to have this thread filled with problems/requests about sketchup .
                    Elisei (sketchupper)
                    Come and See EliseiDesign
                    • F Offline
                      fcborik
                      The link is good, but the bug reporting system does not list SU 2013 as an option. (Minor problem, just put it in the text.)
                      • sketch3d.deS Offline
                        sketch3d.de
                        and the recent Contact Support form can be found at:
                        http://help.sketchup.com/en/contact/pro-support
                        Norbert
                        • GwyattG Offline
                          Gwyatt
                          Norbert
                          I just loaded a huge model in to SKP 2013 trial, and was like owning a AMD dual core 2gig system again.
                          running like this is not fun or enjoyable, sent information to SKP as per link asking them why are they treating users like "Lord of the rings"... "Ooooo shinny Buttons Master,, Must have shinny buttons"
                          List of 3D modeling software - Wikipedia
                          (en.wikipedia.org)
                          • V Offline
                            victor hugo
                            Hello.
                            I'm trying to start a session of SU and I get bugsplat (attached error message) does anyone had this problem that can help me?
                            Thanks.
                              @Victor
                              If you have recently installed some plugins try disabling them [move them out of the Plugins folder temporarily] then if SketchUp starts OK you know the culprit[s]...
                              Then maybe the cause can traced easier...
                              • V Offline
                                victor hugo
                                Thanks TIG.
                                The one that gives the splat is "Fredo6: Joint Push Pull Interactive v3.1a"
                                is there a way to recover to previous version?
                                Thanks for your reply.
                                  The tool itself is NOT known to cause issues.
                                  Have you also got and installed the very latest Lib for Fredo's tools - available from the PluginStore http://sketchucation.com/pluginstore?pln=LibFredo6
                                  Works fine for me and many other users...
                                  It it's still failing with that latest Lib in tandem... then it might be 'innocent', BUT clashing with a 'less kindly' script...
                                  Do you have any of the known quarantined/rogues loading too ?
                                  SketchyPhysics, some Vray betas, older Podiums, Matchbox, etc...
                                  If so, try again without those...
                                  • V Offline
                                    victor hugo
                                    I have other plugins from Fredo and the Joint Push Pull Interactive v3.1a is the one not working, it was ok before this version and I can't go back to previous one..
                                    I don't have any quarantined ones I saw the quarantined topic already.
                                    Thanks.
                                      slbaumgartner
                                      @thomthom said:
                                      Use this link:
                                      to make official bug reports to SketchUp
                                      When I submit the form at this link I get back an error message about invalid login, despite the fact that the form says nothing about needing a login and has no place to put one!
                                      • tt_suT Offline
                                        tt_su
                                        That form is no longer active. Instead go via: http://help.sketchup.com/en/contact
                                          slbaumgartner
                                          They should take it down if it is defunct!
                                          • tt_suT Offline
                                            tt_su
                                            It will be. No one knew that existed any more.
                                            • 2 / 2
