    Get Link for Official Sketchup Bug Reporting
    28 Posts 14 Posters 10.9k Views 14 Watching
      @nentautako said:
      what's the best computer's specs for SU 7 pro? mine is core 2 duo 2.0, 2 gigs memory and 1650pro 512mb gpu. i always have to terminate the process by TASK MANAGER due to "hang" problem... especially while editing files which are more than 10mb size.... 😐
      What has this got to do with the topic here?
      I smell a sleeper πŸ˜’
      • N
        Nentautako
        [/quote]
        I smell a sleeper πŸ˜’[/quote]
        sorry then, i think this newby doesn't know what's he's talking about. kindly just erase my post.. 😳
        • V
          victor hugo
          Hello..
          For some odd reason I can't start SKU, not new file not even a small file already created when the software is loading it freezes for a while then the sketchup BSOD (BUG SPLAT OFF DEAD) screen shows.
          Is there a solutions for this?
          Gracias.
            What SketchUp version?
            What OS?
            Did it work before?
            Have you tried reinstalling?
            BSOD indicate hardware/driver error. Have you updated your computer's drivers? (Especially the graphic card?)
            What graphic card do you have?
            (Btw - it's better if you create a new topic when you have a question that's new for the topic.)
            • V
              victor hugo
              SKUP Version 8.0.15158
              OS Win XP SP3
              Yes It was working before, I also was getting the "Failed to create empty document" when I was trying to open other session, I think Gaeius had some issue also with the "Failed ....document" thing.
              I will haven't tried reinstalling yet, Which folders do I need to back up if any?
              BSOD I had those as "Blue Screen Of Dead" on other computers for the Windows Driver's, I've just found that it also fits the Bug Splat, video card is updated.
              Video Card NVIDIA Quadro FX550
              Thanks thomthom for your quick response.
              • V
                victor hugo
                Is it possible that this "error/problem" is generated by the Fredo tools update or the updated website, because when I try to update the plugin I get the attached error.
                Thanks.
                  No - Fredo plugins doesn't create BSODs. I'm still betting it's a hardware/driver issue - it always is.
                  • V
                    victor hugo
                    I reinstalled the program and updated the drivers, I've also tried loggin in a using a different user. On the different user I can open multiple sessions but when I go back to my regular user and when I try to open other sessiont it says "Failed to create empty document", this is when I'm lucky to even have on session open.
                    Don't know what to do now, is there a solution for this issue.
                    Thanks.
                    • ely862meE
                      ely862me
                      πŸ˜† I think people take the thread's title as granted !
                      Perhaps changing the title will help not to have this thread filled with problems/requests about sketchup .
                      Elisei (sketchupper)
                      Come and See EliseiDesign
                      • F
                        fcborik
                        The link is good, but the bug reporting system does not list SU 2013 as an option. (Minor problem, just put it in the text.)
                        • sketch3d.deS
                          sketch3d.de
                          and the recent Contact Support form can be found at:
                          http://help.sketchup.com/en/contact/pro-support
                          Norbert
                          • GwyattG
                            Gwyatt
                            Norbert
                            I just loaded a huge model in to SKP 2013 trial, and was like owning a AMD dual core 2gig system again.
                            running like this is not fun or enjoyable, sent information to SKP as per link asking them why are they treating users like "Lord of the rings"... "Ooooo shinny Buttons Master,, Must have shinny buttons"
                            http://en.wikipedia.org/wiki/List_of_3D_modeling_software
                            • V
                              victor hugo
                              Hello.
                              I'm trying to start a session of SU and I get bugsplat (attached error message) does anyone had this problem that can help me?
                              Thanks.
                                @Victor
                                If you have recently installed some plugins try disabling them [move them out of the Plugins folder temporarily] then if SketchUp starts OK you know the culprit[s]...
                                Then maybe the cause can traced easier...
                                • V
                                  victor hugo
                                  Thanks TIG.
                                  The one that gives the splat is "Fredo6: Joint Push Pull Interactive v3.1a"
                                  is there a way to recover to previous version?
                                  Thanks for your reply.
                                    The tool itself is NOT known to cause issues.
                                    Have you also got and installed the very latest Lib for Fredo's tools - available from the PluginStore http://sketchucation.com/pluginstore?pln=LibFredo6
                                    Works fine for me and many other users...
                                    It it's still failing with that latest Lib in tandem... then it might be 'innocent', BUT clashing with a 'less kindly' script...
                                    Do you have any of the known quarantined/rogues loading too ?
                                    SketchyPhysics, some Vray betas, older Podiums, Matchbox, etc...
                                    If so, try again without those...
                                    • V
                                      victor hugo
                                      I have other plugins from Fredo and the Joint Push Pull Interactive v3.1a is the one not working, it was ok before this version and I can't go back to previous one..
                                      I don't have any quarantined ones I saw the quarantined topic already.
                                      Thanks.
                                        slbaumgartner
                                        @thomthom said:
                                        Use this link:
                                        to make official bug reports to SketchUp
                                        When I submit the form at this link I get back an error message about invalid login, despite the fact that the form says nothing about needing a login and has no place to put one!
                                        • tt_suT
                                          tt_su
                                          That form is no longer active. Instead go via: http://help.sketchup.com/en/contact
                                            slbaumgartner
                                            They should take it down if it is defunct!
