    Get Link for Official Sketchup Bug Reporting
    28 Posts 14 Posters 10.9k Views 14 Watching
    • GwyattG
      Gwyatt
      @sketch3d.de said:
      and the recent Contact Support form can be found at:
      http://help.sketchup.com/en/contact/pro-support
      Norbert
      I just loaded a huge model in to SKP 2013 trial, and was like owning a AMD dual core 2gig system again.
      running like this is not fun or enjoyable, sent information to SKP as per link asking them why are they treating users like "Lord of the rings"... "Ooooo shinny Buttons Master,, Must have shinny buttons"
      http://en.wikipedia.org/wiki/List_of_3D_modeling_software
      • V
        victor hugo
        Hello.
        I'm trying to start a session of SU and I get bugsplat (attached error message) does anyone had this problem that can help me?
        Thanks.
          @Victor
          If you have recently installed some plugins try disabling them [move them out of the Plugins folder temporarily] then if SketchUp starts OK you know the culprit[s]...
          Then maybe the cause can traced easier...
          • V
            victor hugo
            Thanks TIG.
            The one that gives the splat is "Fredo6: Joint Push Pull Interactive v3.1a"
            is there a way to recover to previous version?
            Thanks for your reply.
              The tool itself is NOT known to cause issues.
              Have you also got and installed the very latest Lib for Fredo's tools - available from the PluginStore http://sketchucation.com/pluginstore?pln=LibFredo6
              Works fine for me and many other users...
              It it's still failing with that latest Lib in tandem... then it might be 'innocent', BUT clashing with a 'less kindly' script...
              Do you have any of the known quarantined/rogues loading too ?
              SketchyPhysics, some Vray betas, older Podiums, Matchbox, etc...
              If so, try again without those...
              • V
                victor hugo
                I have other plugins from Fredo and the Joint Push Pull Interactive v3.1a is the one not working, it was ok before this version and I can't go back to previous one..
                I don't have any quarantined ones I saw the quarantined topic already.
                Thanks.
                  slbaumgartner
                  @thomthom said:
                  Use this link:
                  to make official bug reports to SketchUp
                  When I submit the form at this link I get back an error message about invalid login, despite the fact that the form says nothing about needing a login and has no place to put one!
                  • tt_suT
                    tt_su
                    That form is no longer active. Instead go via: http://help.sketchup.com/en/contact
                      slbaumgartner
                      They should take it down if it is defunct!
                      • tt_suT
                        tt_su
                        It will be. No one knew that existed any more.
                        • P
                          pgarmyn
                          The official forum to post a bug.
                          Looking to other posts on this forum... I have not the impression that the SU team is on this forum.
                          My bug report on the official SU forum :
                          https://productforums.google.com/forum/m/#!category-topic/sketchup/sketchup-pro/ZEGIk9xpp6U
                          On sketchucation :
                          http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57365%26amp;p=521587#p521587
                          • 2 / 2
