    Get Link for Official Sketchup Bug Reporting
    28 Posts 14 Posters 10.9k Views 14 Watching
      No - Fredo plugins doesn't create BSODs. I'm still betting it's a hardware/driver issue - it always is.
      • V
        victor hugo
        I reinstalled the program and updated the drivers, I've also tried loggin in a using a different user. On the different user I can open multiple sessions but when I go back to my regular user and when I try to open other sessiont it says "Failed to create empty document", this is when I'm lucky to even have on session open.
        Don't know what to do now, is there a solution for this issue.
        Thanks.
        • ely862meE
          ely862me
          πŸ˜† I think people take the thread's title as granted !
          Perhaps changing the title will help not to have this thread filled with problems/requests about sketchup .
          Elisei (sketchupper)
          Come and See EliseiDesign
          • F
            fcborik
            The link is good, but the bug reporting system does not list SU 2013 as an option. (Minor problem, just put it in the text.)
            • sketch3d.deS
              sketch3d.de
              and the recent Contact Support form can be found at:
              http://help.sketchup.com/en/contact/pro-support
              Norbert
              • GwyattG
                Gwyatt
                Norbert
                I just loaded a huge model in to SKP 2013 trial, and was like owning a AMD dual core 2gig system again.
                running like this is not fun or enjoyable, sent information to SKP as per link asking them why are they treating users like "Lord of the rings"... "Ooooo shinny Buttons Master,, Must have shinny buttons"
                http://en.wikipedia.org/wiki/List_of_3D_modeling_software
                • V
                  victor hugo
                  Hello.
                  I'm trying to start a session of SU and I get bugsplat (attached error message) does anyone had this problem that can help me?
                  Thanks.
                    @Victor
                    If you have recently installed some plugins try disabling them [move them out of the Plugins folder temporarily] then if SketchUp starts OK you know the culprit[s]...
                    Then maybe the cause can traced easier...
                    • V
                      victor hugo
                      Thanks TIG.
                      The one that gives the splat is "Fredo6: Joint Push Pull Interactive v3.1a"
                      is there a way to recover to previous version?
                      Thanks for your reply.
                        The tool itself is NOT known to cause issues.
                        Have you also got and installed the very latest Lib for Fredo's tools - available from the PluginStore http://sketchucation.com/pluginstore?pln=LibFredo6
                        Works fine for me and many other users...
                        It it's still failing with that latest Lib in tandem... then it might be 'innocent', BUT clashing with a 'less kindly' script...
                        Do you have any of the known quarantined/rogues loading too ?
                        SketchyPhysics, some Vray betas, older Podiums, Matchbox, etc...
                        If so, try again without those...
                        • V
                          victor hugo
                          I have other plugins from Fredo and the Joint Push Pull Interactive v3.1a is the one not working, it was ok before this version and I can't go back to previous one..
                          I don't have any quarantined ones I saw the quarantined topic already.
                          Thanks.
                            slbaumgartner
                            @thomthom said:
                            Use this link:
                            to make official bug reports to SketchUp
                            When I submit the form at this link I get back an error message about invalid login, despite the fact that the form says nothing about needing a login and has no place to put one!
                            • tt_suT
                              tt_su
                              That form is no longer active. Instead go via: http://help.sketchup.com/en/contact
                                slbaumgartner
                                They should take it down if it is defunct!
                                • tt_suT
                                  tt_su
                                  It will be. No one knew that existed any more.
                                  • P
                                    pgarmyn
                                    The official forum to post a bug.
                                    Looking to other posts on this forum... I have not the impression that the SU team is on this forum.
                                    My bug report on the official SU forum :
                                    https://productforums.google.com/forum/m/#!category-topic/sketchup/sketchup-pro/ZEGIk9xpp6U
                                    On sketchucation :
                                    http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=57365%26amp;p=521587#p521587
                                    • 2 / 2
