    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 314.3k Views 135 Watching
      Didn't you mean
      010110010110111101110101001000000110010001101111001000000110111001101111011101000010000001110101011011100110010001100101011100100111001101110100011000010110111001100100001000000110001001101001011011100110000101110010011110010010000000100001
      πŸ˜• πŸ˜‰
        01101000 01101111 01110111 00100000 01110010 01110101 01100100 01100101 00100001
          It wasn't... but
          0100011001100101011000110110101100100000011010010111001100100000011100100111010101100100011001010010000000100001
            mrossk
            I think I got geek all over me πŸ˜‰
            https://www.mkaplanfinefurniture.com/
              πŸ’š
              	100001
              	11000
              	1110
              	100011
              	1100
              	10001
              	100100
              	11110
                Found a cool one today.
                Copy a line over and type 6" to set the distance. Then type *10 to array it 10 times.
                What I already knew was that you can type *8 or *4 or whatever to adjust the number of arrayed items.
                However I just found out that if you type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                -Brodie
                Duh!
                That is sweet!
                The manual doesn't even mention this!
                http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94863
                • H Offline
                  Heaps
                  It even works with circular arrays - just type in the angle in degrees
                  • brodieB Offline
                    brodie
                    However I just found out that if you then type 3" or 10" it will keep your array but adjust the spacing. Pretty sweet!
                    -Brodie
                    • broomstickB Offline
                      broomstick
                      -Brodie
                      This, sir, just made my day!
                      • Bob JamesB Offline
                        Bob James
                        • jgbJ Offline
                          jgb
                          Found a cool one today. πŸ˜’
                          -Brodie
                          I just wish you found this last week, when I needed it. πŸ˜†
                          jgb
                            d12dozr
                            -Brodie
                            I learned that just a couple months ago from Dave R at a local meetup πŸ‘
                            http://goo.gl/f7ooYh
                            • aarondietzenA Offline
                              aarondietzen
                              Shift + Eraser to smooth...
                              I know that this has always been there, but I just discovered it recently (Duh!) thanks to another thread here... I cannot tell you how many times I have tweaked, and redone a push/pull or follow me command just to minimize the number of lines on a solid!
                              Ah... feels good to share my stupidity!
                              "Imagination is more important than knowledge..."
                              - Albert Einstein
                              • massimoM Offline
                                massimo Moderator
                                Ctrl+ eraser is to smooth. Shift+eraser is to hide. πŸ˜‰
                                  aarondietzen
                                  Stupidity x2! πŸ˜†
                                  - Albert Einstein
                                    Ctrl+Erase = Soft+Smooth
                                    Shift+Erase = Hide
                                    Ctrl+Shift+Erase = Un-soft+Smooth (But not Unhide!)
                                      Shift+Erase = Hide
                                      Use 'Entity Info' to manipulate selected edges' hidden/soft/smooth status OR alternatively use the context-menu 'Unhide' [or 'Hide']...
                                        aarondietzen
                                        @tig said:
                                        Shift+Erase = Hide
                                        "Learn something new everyday!"
                                        In this case... several new things.
                                        - Albert Einstein
                                          -Brodie
                                          Duh!
                                          That is sweet!
                                          Seems that is more missing here πŸ˜‰
                                          http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867&topic=2458142&ctx=topic
                                          • emerald15E Offline
                                            emerald15
                                            You've lost me now...I usually type in x(number) not *(number). But how do I get back to degrees... how does one type 'degrees'! ACAD is 'dd%d' but what is SU?
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 34
                                            • 35
                                            • 27 / 35
