    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
    • bazB Offline
      baz
      Great stuff Fredo, thanks.
      Baz
      • fredo6F Offline
        NEW RELEASE
        version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
        Note that the parameter "angle of influence" is no longer used.
        Version 2.0b also includes the Italian translation
        See main post for download.
          πŸ‘ πŸ‘
          • pep75P Offline
            pep75
            Fredo is the man!
            grtzzz
            Pep
            • N Offline
              niks
              just wanted to say THANK YOU πŸ‘Š
                BBLV
                Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
                Example of desired finished result:
                http://www.glumber.com/WoodTopSubpages/Details/EdgeTreatmentData/EdgeTreatmentSubPages/Edge_Profile_Photos/Roundover/HalfInchRoundover.jpg
                • mitcorbM Offline
                  mitcorb
                  Hi, BBLV:
                  You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
                    rock1
                    using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
                    Signature removed by SCF Admin
                    • Rich O BrienR Online
                      With face and tool selected...
                      Press TAB to open dialogue box
                      Choose Finishing Options
                      Pick option
                        rock1
                        Pick option
                        http://i.imgur.com/BOHLQ.jpg
                        I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
                          What is your question? Your image doesn't show anything useful as far as a problem is concerned.
                            It's not a telepathic tool - just erase lines and faces that YOU don't want!
                            • fredo6F Offline
                              yes it works like a Ctrl+pull.
                              Actually, doing like the native push pull is much more complex for:
                              • creating holes
                              • merging the surfaces after push pull
                                Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
                              I suggest you simply erase the unwanted lines.
                              Fred
                                rock1
                                Fred
                                In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
                                • massimoM Offline
                                  massimo Moderator
                                  If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools.
                                    Feature request: Option to disable the Context Menu.
                                      +1 πŸ‘
                                      [I have already tweaked my copy so that there's no context-menu, as there are already too many things clogging mine up!]
                                        Yea - I use to tweak it myself. But for each update I need to do it all over again.
                                          paihwai
                                          Oh!!!
                                          • gtalaricoG Offline
                                            gtalarico
                                            I keep getting an error when trying to extrude a few curved letters...
                                            "General Error: cannot complete the transformation"
                                            Can someone give it try it a try and see if maybe it is something on my end?
                                            Steps to reproduce:
                                            1. Open groud
                                            2. Select All.
                                              3.Click on JPP (J)
                                              [ Erase Original, border on all, make group, 30 deg]
                                              4.Click on edge, pull, type 2", Enter
                                            Error.
                                            letters.skp
                                            -Gui
                                            http://www.gtalarico.com
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 19 / 19
