    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
    • fredo6F Offline
      NEW RELEASE
      version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
      Note that the parameter "angle of influence" is no longer used.
      See main post for download.
        Thanks Fredo. Much appreciated πŸ‘
        • bazB Offline
          baz
          Great stuff Fredo, thanks.
          Baz
          • fredo6F Offline
            NEW RELEASE
            version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
            Version 2.0b also includes the Italian translation
              πŸ‘ πŸ‘
              • pep75P Offline
                pep75
                Fredo is the man!
                grtzzz
                Pep
                • N Offline
                  niks
                  just wanted to say THANK YOU πŸ‘Š
                    BBLV
                    Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
                    Example of desired finished result:
                    http://www.glumber.com/WoodTopSubpages/Details/EdgeTreatmentData/EdgeTreatmentSubPages/Edge_Profile_Photos/Roundover/HalfInchRoundover.jpg
                    • mitcorbM Offline
                      mitcorb
                      Hi, BBLV:
                      You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
                        rock1
                        using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
                        Signature removed by SCF Admin
                          With face and tool selected...
                          Press TAB to open dialogue box
                          Choose Finishing Options
                          Pick option
                            rock1
                            Pick option
                            http://i.imgur.com/BOHLQ.jpg
                            I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
                              What is your question? Your image doesn't show anything useful as far as a problem is concerned.
                                It's not a telepathic tool - just erase lines and faces that YOU don't want!
                                • fredo6F Offline
                                  yes it works like a Ctrl+pull.
                                  Actually, doing like the native push pull is much more complex for:
                                  • creating holes
                                  • merging the surfaces after push pull
                                    Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
                                  I suggest you simply erase the unwanted lines.
                                  Fred
                                    rock1
                                    Fred
                                    In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
                                    • massimoM Offline
                                      massimo Moderator
                                      If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools.
                                        Feature request: Option to disable the Context Menu.
                                          +1 πŸ‘
                                          [I have already tweaked my copy so that there's no context-menu, as there are already too many things clogging mine up!]
                                            Yea - I use to tweak it myself. But for each update I need to do it all over again.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
