    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
      rock1
      With face and tool selected...
      Press TAB to open dialogue box
      Choose Finishing Options
      Pick option
      http://i.imgur.com/BOHLQ.jpg
      I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
      Signature removed by SCF Admin
        What is your question? Your image doesn't show anything useful as far as a problem is concerned.
          It's not a telepathic tool - just erase lines and faces that YOU don't want!
          • fredo6F Offline
            @rock1 said:
            using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
            yes it works like a Ctrl+pull.
            Actually, doing like the native push pull is much more complex for:
            • creating holes
            • merging the surfaces after push pull
              Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
            I suggest you simply erase the unwanted lines.
            Fred
              rock1
              Fred
              In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
              • massimoM Offline
                massimo Moderator
                If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools.
                  Feature request: Option to disable the Context Menu.
                    +1 ๐Ÿ‘
                    [I have already tweaked my copy so that there's no context-menu, as there are already too many things clogging mine up!]
                      Yea - I use to tweak it myself. But for each update I need to do it all over again.
                        paihwai
                        Oh!!!
                        • gtalaricoG Offline
                          gtalarico
                          I keep getting an error when trying to extrude a few curved letters...
                          "General Error: cannot complete the transformation"
                          Can someone give it try it a try and see if maybe it is something on my end?
                          Steps to reproduce:
                          1. Open groud
                          2. Select All.
                            3.Click on JPP (J)
                            [ Erase Original, border on all, make group, 30 deg]
                            4.Click on edge, pull, type 2", Enter
                          Error.
                          letters.skp
                          -Gui
                          http://www.gtalarico.com
                            driven
                            try booleenhelper.rb or scale X 1000 enter 2000" and it works here
                              Interesting. I could do one letter at a time at the current size. I selected about half of them and tried it and got a Bug Splat. ๐Ÿ˜ž
                              I tried doing limited groups of letters. The center row went fine as did the first two thirds of the top row. When I tried to do the last batch of letters in the top row, Splat!
                                I got splats on the 'r 'in 'marian' and 'heart'.
                                  At original size it Bugsplats big time! [probably a 'tiny facets issue' on the small curved edges in the R - but why not the P or & ?]
                                  But Scale x100 and then JPP 200" [on the whole thing at once], then Scale back down x0.01m to get this good/swift outcome Capture.PNG
                                    gtalarico
                                    Scaling helped. Thanks! ๐Ÿ˜‰
                                    Never thought it make a difference... is because SU doesn't like expressions with number like 0.00000000000000000000000000000000002003 ? ๐Ÿ˜’
                                    -Gui
                                    • ayan13A Offline
                                      ayan13
                                      great plugins ! I use it a lot! Thank you !!!
                                      • H Offline
                                        helios
                                        My apologies if this was answered before, but is it possible to use this plugin to uniformly add thickness to a cylinder-like object? I created it by pulling a circle (and then scaling it at several points) and now would like to add some thickness to the currently hollow object, as it is going to be 3D printed. I am, in essence, trying to pull all the outside surfaces at a perpendicular angles.
                                        Many thanks!
                                        • jgbJ Offline
                                          jgb
                                          Yes. Use the Joint Push/Pull (not the Vector). Select the surface of the cylinder and using the JPP tool, click on any face in the selection. It will outline in red. Pull it up as thick as you want, or more accurately, pull up a short distance and type the thickness to the Measurements box. Press <Enter> to get a preview, then <enter> again to complete the thickening.
                                          Depending on the defaults you have for JPP, it may or may not form a group of the thickened section.
                                          You can explode the group if you want.
                                          jgb
                                          • jgbJ Offline
                                            jgb
                                            I just got that "transformation" error as well. ๐Ÿ˜ฎ
                                            While the attached SKP is documented, here's what happened.
                                            There are 2 errors depicted in the attached model.
                                            1 - I tried to thicken (using JPP preset at 90 deg) the housing by .1 inch. Error.
                                            I read this thread and scaled up 10X, same result.
                                            If I do the hub and flanges separately, it works, but there is a mess to clean up.
                                            2 - When I thicken any pair (or more) faces that are at an angle to each other, and any face has a hole in it, the hole thickens at some median angle, not perpendicular to its face. The circle on the thickened face is also distorted into an oval/ellipse.
                                            There is one other transformation error I've noticed as well, but seems to happen in specific repeatable cases where the transformation logic is simply stumped for a good solution.
                                            Ya kant code for every case.... bin-der dundat. ๐Ÿ˜† (Well respected Indian explorer)
                                            I'll post a separate model of that problem if wanted.
                                            So now in those cases I know where to look and do a quick and simple fix.
                                            Believe me, JPP is a Golden Ruby I cannot live without.
                                            Apologies... First post I forgot the SKP file. ๐Ÿ˜ณ
                                            As above.
                                            jgb
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 18
                                            • 19
                                            • 13 / 19
