    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.2m Views 150 Watching
    • mitcorbM
      mitcorb
      Hi, BBLV:
      You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
        rock1
        using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
        Signature removed by SCF Admin
          With face and tool selected...
          Press TAB to open dialogue box
          Choose Finishing Options
          Pick option
            rock1
            Pick option
            http://i.imgur.com/BOHLQ.jpg
            I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
              What is your question? Your image doesn't show anything useful as far as a problem is concerned.
                It's not a telepathic tool - just erase lines and faces that YOU don't want!
                • fredo6F
                  yes it works like a Ctrl+pull.
                  Actually, doing like the native push pull is much more complex for:
                  • creating holes
                  • merging the surfaces after push pull
                    Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
                  I suggest you simply erase the unwanted lines.
                  Fred
                    rock1
                    Fred
                    In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
                    • massimoM
                      massimo Moderator
                      If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools.
                        Feature request: Option to disable the Context Menu.
                          +1 ๐Ÿ‘
                          [I have already tweaked my copy so that there's no context-menu, as there are already too many things clogging mine up!]
                            Yea - I use to tweak it myself. But for each update I need to do it all over again.
                            • P
                              paihwai
                              Oh!!!
                              • gtalaricoG
                                gtalarico
                                I keep getting an error when trying to extrude a few curved letters...
                                "General Error: cannot complete the transformation"
                                Can someone give it try it a try and see if maybe it is something on my end?
                                Steps to reproduce:
                                1. Open groud
                                2. Select All.
                                  3.Click on JPP (J)
                                  [ Erase Original, border on all, make group, 30 deg]
                                  4.Click on edge, pull, type 2", Enter
                                Error.
                                letters.skp
                                -Gui
                                http://www.gtalarico.com
                                  driven
                                  try booleenhelper.rb or scale X 1000 enter 2000" and it works here
                                    Interesting. I could do one letter at a time at the current size. I selected about half of them and tried it and got a Bug Splat. ๐Ÿ˜ž
                                    I tried doing limited groups of letters. The center row went fine as did the first two thirds of the top row. When I tried to do the last batch of letters in the top row, Splat!
                                      I got splats on the 'r 'in 'marian' and 'heart'.
                                        At original size it Bugsplats big time! [probably a 'tiny facets issue' on the small curved edges in the R - but why not the P or & ?]
                                        But Scale x100 and then JPP 200" [on the whole thing at once], then Scale back down x0.01m to get this good/swift outcome Capture.PNG
                                        • gtalaricoG
                                          gtalarico
                                          Scaling helped. Thanks! ๐Ÿ˜‰
                                          Never thought it make a difference... is because SU doesn't like expressions with number like 0.00000000000000000000000000000000002003 ? ๐Ÿ˜’
                                          -Gui
                                          • ayan13A
                                            ayan13
                                            great plugins ! I use it a lot! Thank you !!!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
