    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
    • W Offline
      winnie70020807
      thanks~
        RizkySyahputra
        it's amazing πŸ‘ πŸ˜›
        • fredo6F Offline
          NEW RELEASE
          version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
          Note that the parameter "angle of influence" is no longer used.
          See main post for download.
            Thanks Fredo. Much appreciated πŸ‘
            • bazB Offline
              baz
              Great stuff Fredo, thanks.
              Baz
              • fredo6F Offline
                NEW RELEASE
                version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                Version 2.0b also includes the Italian translation
                  πŸ‘ πŸ‘
                  • pep75P Offline
                    pep75
                    Fredo is the man!
                    grtzzz
                    Pep
                    • N Offline
                      niks
                      just wanted to say THANK YOU πŸ‘Š
                        BBLV
                        Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
                        Example of desired finished result:
                        http://www.glumber.com/WoodTopSubpages/Details/EdgeTreatmentData/EdgeTreatmentSubPages/Edge_Profile_Photos/Roundover/HalfInchRoundover.jpg
                        • mitcorbM Offline
                          mitcorb
                          Hi, BBLV:
                          You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
                            rock1
                            using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
                            Signature removed by SCF Admin
                              With face and tool selected...
                              Press TAB to open dialogue box
                              Choose Finishing Options
                              Pick option
                                rock1
                                Pick option
                                http://i.imgur.com/BOHLQ.jpg
                                I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
                                  What is your question? Your image doesn't show anything useful as far as a problem is concerned.
                                    It's not a telepathic tool - just erase lines and faces that YOU don't want!
                                    • fredo6F Offline
                                      yes it works like a Ctrl+pull.
                                      Actually, doing like the native push pull is much more complex for:
                                      • creating holes
                                      • merging the surfaces after push pull
                                        Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
                                      I suggest you simply erase the unwanted lines.
                                      Fred
                                        rock1
                                        Fred
                                        In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
                                        • massimoM Offline
                                          massimo Moderator
                                          If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools.
                                            Feature request: Option to disable the Context Menu.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
