    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
    • fredo6F Offline
      I just posted a 'fresh' zip file in the main post.
        I can confirm that the unwanted empty v17 folder is no longer in the zip file πŸ˜„
        • W Offline
          winnie70020807
          thanks~
            RizkySyahputra
            it's amazing πŸ‘ πŸ˜›
            • fredo6F Offline
              NEW RELEASE
              version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
              Note that the parameter "angle of influence" is no longer used.
              See main post for download.
                Thanks Fredo. Much appreciated πŸ‘
                • bazB Offline
                  baz
                  Great stuff Fredo, thanks.
                  Baz
                  • fredo6F Offline
                    NEW RELEASE
                    version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                    Version 2.0b also includes the Italian translation
                      πŸ‘ πŸ‘
                      • pep75P Offline
                        pep75
                        Fredo is the man!
                        grtzzz
                        Pep
                        • N Offline
                          niks
                          just wanted to say THANK YOU πŸ‘Š
                            BBLV
                            Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
                            Example of desired finished result:
                            http://www.glumber.com/WoodTopSubpages/Details/EdgeTreatmentData/EdgeTreatmentSubPages/Edge_Profile_Photos/Roundover/HalfInchRoundover.jpg
                            • mitcorbM Offline
                              mitcorb
                              Hi, BBLV:
                              You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
                                rock1
                                using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
                                Signature removed by SCF Admin
                                  With face and tool selected...
                                  Press TAB to open dialogue box
                                  Choose Finishing Options
                                  Pick option
                                    rock1
                                    Pick option
                                    http://i.imgur.com/BOHLQ.jpg
                                    I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
                                      What is your question? Your image doesn't show anything useful as far as a problem is concerned.
                                        It's not a telepathic tool - just erase lines and faces that YOU don't want!
                                        • fredo6F Offline
                                          yes it works like a Ctrl+pull.
                                          Actually, doing like the native push pull is much more complex for:
                                          • creating holes
                                          • merging the surfaces after push pull
                                            Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
                                          I suggest you simply erase the unwanted lines.
                                          Fred
                                            rock1
                                            Fred
                                            In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
