    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.2m Views 150 Watching
      πŸ‘ πŸ‘
      • pep75P
        pep75
        Fredo is the man!
        grtzzz
        Pep
        • N
          niks
          just wanted to say THANK YOU πŸ‘Š
          • B
            BBLV
            Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
            Example of desired finished result:
            http://www.glumber.com/WoodTopSubpages/Details/EdgeTreatmentData/EdgeTreatmentSubPages/Edge_Profile_Photos/Roundover/HalfInchRoundover.jpg
            • mitcorbM
              mitcorb
              Hi, BBLV:
              You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
                rock1
                using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
                Signature removed by SCF Admin
                  With face and tool selected...
                  Press TAB to open dialogue box
                  Choose Finishing Options
                  Pick option
                    rock1
                    Pick option
                    http://i.imgur.com/BOHLQ.jpg
                    I chose thickening, then erase original faces, then keep original faces. All the options are giving the same results with the lines :?
                      What is your question? Your image doesn't show anything useful as far as a problem is concerned.
                        It's not a telepathic tool - just erase lines and faces that YOU don't want!
                        • fredo6F
                          yes it works like a Ctrl+pull.
                          Actually, doing like the native push pull is much more complex for:
                          • creating holes
                          • merging the surfaces after push pull
                            Note however that in most cases, JPP is used for complex surfaces where the standrad push pull would not be effective. So the continuity of surface won't really happen.
                          I suggest you simply erase the unwanted lines.
                          Fred
                            rock1
                            Fred
                            In the case shown above is it possible that the pulling is like a normal pull? My shape isn't complex enough :lol:
                            • massimoM
                              massimo Moderator
                              If I understood well can't you just use the "vector pushpull"? Anyway here you have the behaviour of the three tools.
                                Feature request: Option to disable the Context Menu.
                                  +1 πŸ‘
                                  [I have already tweaked my copy so that there's no context-menu, as there are already too many things clogging mine up!]
                                    Yea - I use to tweak it myself. But for each update I need to do it all over again.
                                    • P
                                      paihwai
                                      Oh!!!
                                      • gtalaricoG
                                        gtalarico
                                        I keep getting an error when trying to extrude a few curved letters...
                                        "General Error: cannot complete the transformation"
                                        Can someone give it try it a try and see if maybe it is something on my end?
                                        Steps to reproduce:
                                        1. Open groud
                                        2. Select All.
                                          3.Click on JPP (J)
                                          [ Erase Original, border on all, make group, 30 deg]
                                          4.Click on edge, pull, type 2", Enter
                                        Error.
                                        letters.skp
                                        -Gui
                                        http://www.gtalarico.com
                                          driven
                                          try booleenhelper.rb or scale X 1000 enter 2000" and it works here
                                            Interesting. I could do one letter at a time at the current size. I selected about half of them and tried it and got a Bug Splat. 😞
                                            I tried doing limited groups of letters. The center row went fine as did the first two thirds of the top row. When I tried to do the last batch of letters in the top row, Splat!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 18
                                            • 19
                                            • 12 / 19
