    1.3k Posts 299 Posters 2.7m Views 297 Watching
      A Torus is easily made using the built-in FollowMe tool or even my EEbyLathe - BUT Fredo's new tool seems far more powerful, and so it should be able to do much greater things 🎉
      We await in anticipation...
      • soloS Offline
        Okay, let's up the ante.
        and this.skp
          Daniel S
          For loft along path you always show two faces or surface and a path...
          It will be possible to select more faces?
          Something like this image that I found:
          https://forum.solidworks.com/servlet/JiveServlet/downloadImage/2-149439-7018/450-194/3-25-2010+9-53-54+AM.png
          And I attach some models to see if they work with loft along path.
          Daniel S
          loft along path tests.skp
          • bagateloB Offline
            bagatelo
            One more video, on the possibility to borrow contours from within components....
            [attachment=0:23rqfyk7]<!-- ia0 -->Contour components.gif<!-- ia0 -->[/attachment:23rqfyk7]
            This remember solidworks. Non destructive work can be very interesting. And if can be possible to make smooth junctions.
            Fredo, never doubt: WE LOVE YOU!!!
              driven
              hi Fredo,
              if you need a mac tester...
              this is a simple version of something I can't get any of the other tools to manage easily, but maybe it's me...
              low-poly version of with a simplified path and face
              cantfollow.skp
                Daniel S
                I don´t know how to explain it in english, but you follow and rotate. So if curviloft works with closed paths and you can select more than 2 faces you will need to make something like the attachment.
                Not really sure, but this is how should work this feature Fredo?
                Daniel S
                cantfollow2.skp
                  DIEGO-RODRIGUEZ
                  Hi FREDO
                  I have drawn some models for you to teste the loft plugins
                  you need other models?
                  http://img8.imageshack.us/img8/870/sinttulo1ta.jpg
                  Sin título.skp
                    Panga
                    Hi Fredo,
                    As promised, I attach to this post some test files in order you can evaluate your plugin with terrain work.
                    The first file (road test.skp), show you one of my principal process in order to make roads, and the boring step of cleaning the faces outside the original contours after using the sandbox...I weld all the contours of the road, but I think you'll have to create somme edges in order to divide the whole road in parts.
                    The second file are classic contours for terrain.
                    Hope it will help you to test your plugin.
                    Regards.
                    Road test.skp
                    Terrain test.skp
                      Rainie
                      When it is released. This was just a teaser. 😉
                      Hi, Thanks Thom for your very quick reply..Thanks!
                        gofrez
                        When i've seen this plugin i falled down the chair!! Amazing Fredo!!
                        Frez
                          Daniel S
                          Here I make another quick test for loft feature. It´s simple but y really want to know if it would work in this cases.
                          Daniel S
                          Pencil for loft.skp
                            robert111
                            i like this plugin, but i dont see link to dowload it
                            can anyone have link for this good plugin??
                            • soloS Offline
                              See title, it's a 'Preview', the plugin is still under construction and is not yet available.
                              • H Offline
                                Howard leslie
                                Fredo,
                                Looks really good.
                                See attached file - a question for both you Fredo and TIG
                                The Demo video shows clicking of 3 or 4 seperate lines.
                                Will it be able to skin the attached file - a closed (welded) single polyline ???
                                or would it have to be broken up into 3 or 4 seperate polylines first ???
                                Maybe one of TIGs Extrude Tools can handle closed polylines like the attached file ???
                                This would be really useful and a feature I'd request if this Script doesn't do it already
                                (or if TIGs Extrude Tool doesn't already do it).
                                Regards
                                Howard L'
                                BoatHull_Half.skp
                                • H Offline
                                  heatsun
                                  Realy cool, thank U for the sharing!!!
                                  • W Offline
                                    weizxwilliam
                                    Wooo. this is cool. it must be award for your amazing job 😄
                                    • fredo6F Offline
                                      @diego-rodriguez said:
                                      Hi FREDO
                                      Diego
                                      Many thanks for the examples. Here is the results, in video (quickly done), but before a few remarks:
                                      • the script does not support Sweep (i.e. Loft along two paths)
                                      • when contours are borrowed from component, you have to do a manual selection, because SU does not let you select edges within and outside component at the same time.
                                      • Holes are not supported directly. You need to generate the loft surface for each contour, inner and outer (just imagine that you can have many holes, and that you cannot edit the inner part if the outer part is generated at the same time)
                                      • I am still struggling to understand how SU orient faces when generated them. So for the time being, junctions may be oriented up or down (this can anyway easily be fixed afterward with Orient Faces and Reverse Faces).
                                      1. the easy ones
                                      2. Loft along path with 2 tubes
                                      3. This one shows that the script has still an issue with the vertex matching. But this is a way to also show how to correct it by editing the vertex matching.
                                      4. Another loft along path
                                      5. Some skinning, one still with an issue (a bug in SU API for colinear edges)
                                      Sin título - Diego - curviloft.skp
                                        DIEGO-RODRIGUEZ
                                        fredo excellent.
                                        models if you need more let me know.
                                        "Fredo:- the script does not support Sweep (i.e. Loft along two paths)"
                                        perhaps the plugins of kilrill, you help.
                                        the uses a second paths who calls " pick pathface adjuste curve"
                                        a question.
                                        the interface (panel floating bar) could be programmed in html?
                                        perhaps more could be done similar to dialog boxes of sketchup
                                        regards
                                          From what I understand, the face direction depends in the direction the points are added. Clockwise or counter-clockwise.
                                            gofrez
                                            Great Dude! This is making the history of SU!
                                            • 65
                                            • 66
                                            • 3 / 66
