    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • fredo6F
      @diego-rodriguez said:
      floating panel interface, which uses programming language?
      you can use images *. png or other format for icons?
      It is written in pure Ruby and SU API (which makes it portable PC and Mac).
      Unfortunately, png cannot be used (the SU API is missing this functionality, but it would be a good idea to add it)
      when can download the first version of the plugins?
      Probably not before a month, except if I released only a subset.
      This is also why I need to have some sample geometry, beyond what I am doing test with, because I prefer to adapt the algorithm before the script is released)
      • fredo6F
        @earthmover said:
        Holy crap!!! Is that speed realtime? Looks amazing! Do the number of segments in the rails matter? Could this possibly be used to replace the standard from contours in the sandbox tools to create graded terrains?
        Videos are real time. As usal the performance is driven by the number of facets created, with the exponential slow-down noticed in all scripts.
        The number of segments does matter because Curviloft always respects the vertices of the contours and rails. This is why meshes created can be unbalanced or very crowded. In principle, it would be good that users do a rebalancing before applying Curviloft.
        For terrain shaping, I would appreciate if you had an example, so that I can answer more accurately.
        • soloS
          Fredo, what kind of example would work for you?
          contour maps, completed terrains, an image, point cloud?
          • bagateloB
            bagatelo
            Yes, Only Fredo6... OMG
            I can't wait to try this one.
            • FletchF
              Fletch
              Fredo, this is simply astounding work, you are absolutely incredible! ☀
              Fletch
              • fredo6F
                Actually, a SKP model with contours where you want to generate the surface. Curviloft does not work on point clouds.
                  I've also requested that SU supports this.
                  Meanwhile, I've made a framework to read BMP images and render them to screen. Though you can't have too many as it'll slow down. But it works fine for creating toolbars.
                  • fredo6F
                    Tom,
                    This was also my first approach (with view.draw GL_POINTS) but it was definitely too slow. I think that if this is added in native code, it can be ultra fast, even fatser than drawing lines and polygons by view.draw.
                      What speeds up thing greatly is if when you load the bitmaps you sort the pixels by colour, and then draw each colour in bulk.
                      I load each bitmap for each toolbar button into a hash with the colour as key and the value as an array of point3d objects. Note that I merge all buttons into one hash.
                      This means that if you are careful about your icon creation and use a palette of fewer colours you increase performance. A little bit pre-processing required, but the bulk drawing makes up for it many times over.
                      • fredo6F
                        One more video, on the possibility to borrow contours from within components....
                          • EscapeArtistE
                            EscapeArtist
                            That last process vid you just posted would be a great time saver all by itself. I'm trying to think of something creative to offer as a sample, but you've covered pretty much what I'd use already.
                            • EarthMoverE
                              EarthMover
                              Bloody genius! I'd swear I was looking a video from Rhino or Bonzai!!! 👍 👍
                              Content Creator at Skapeup
                                On the last example, the curve can make a loop on the same plan?
                                If yes,there is an automatic clean of the complex auto-intersect skin resulting?
                                • soloS
                                  oooh, good thinking.
                                  Would it make a torus shape?
                                  try this.skp
                                    A Torus is easily made using the built-in FollowMe tool or even my EEbyLathe - BUT Fredo's new tool seems far more powerful, and so it should be able to do much greater things 🎉
                                    We await in anticipation...
                                    • soloS
                                      Okay, let's up the ante.
                                      and this.skp
                                        Daniel S
                                        For loft along path you always show two faces or surface and a path...
                                        It will be possible to select more faces?
                                        Something like this image that I found:
                                        https://forum.solidworks.com/servlet/JiveServlet/downloadImage/2-149439-7018/450-194/3-25-2010+9-53-54+AM.png
                                        And I attach some models to see if they work with loft along path.
                                        Daniel S
                                        loft along path tests.skp
                                        • bagateloB
                                          bagatelo
                                          [attachment=0:23rqfyk7]<!-- ia0 -->Contour components.gif<!-- ia0 -->[/attachment:23rqfyk7]
                                          This remember solidworks. Non destructive work can be very interesting. And if can be possible to make smooth junctions.
                                          Fredo, never doubt: WE LOVE YOU!!!
                                            driven
                                            hi Fredo,
                                            if you need a mac tester...
                                            this is a simple version of something I can't get any of the other tools to manage easily, but maybe it's me...
                                            low-poly version of with a simplified path and face
                                            cantfollow.skp
                                            • 65
                                            • 66
                                            • 3 / 66
