    1.3k Posts 299 Posters 2.6m Views 297 Watching
    • fredo6F Offline
      One more video, on the possibility to borrow contours from within components....
        ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
        • EscapeArtistE Offline
          EscapeArtist
          That last process vid you just posted would be a great time saver all by itself. I'm trying to think of something creative to offer as a sample, but you've covered pretty much what I'd use already.
          • EarthMoverE Offline
            EarthMover
            Bloody genius! I'd swear I was looking a video from Rhino or Bonzai!!! ๐Ÿ‘ ๐Ÿ‘
            Content Creator at Skapeup
              On the last example, the curve can make a loop on the same plan?
              If yes,there is an automatic clean of the complex auto-intersect skin resulting?
              • soloS Offline
                oooh, good thinking.
                Would it make a torus shape?
                try this.skp
                  A Torus is easily made using the built-in FollowMe tool or even my EEbyLathe - BUT Fredo's new tool seems far more powerful, and so it should be able to do much greater things ๐ŸŽ‰
                  We await in anticipation...
                  • soloS Offline
                    Okay, let's up the ante.
                    and this.skp
                      Daniel S
                      For loft along path you always show two faces or surface and a path...
                      It will be possible to select more faces?
                      Something like this image that I found:
                      https://forum.solidworks.com/servlet/JiveServlet/downloadImage/2-149439-7018/450-194/3-25-2010+9-53-54+AM.png
                      And I attach some models to see if they work with loft along path.
                      Daniel S
                      loft along path tests.skp
                      • bagateloB Offline
                        bagatelo
                        [attachment=0:23rqfyk7]<!-- ia0 -->Contour components.gif<!-- ia0 -->[/attachment:23rqfyk7]
                        This remember solidworks. Non destructive work can be very interesting. And if can be possible to make smooth junctions.
                        Fredo, never doubt: WE LOVE YOU!!!
                          driven
                          hi Fredo,
                          if you need a mac tester...
                          this is a simple version of something I can't get any of the other tools to manage easily, but maybe it's me...
                          low-poly version of with a simplified path and face
                          cantfollow.skp
                            Daniel S
                            I donยดt know how to explain it in english, but you follow and rotate. So if curviloft works with closed paths and you can select more than 2 faces you will need to make something like the attachment.
                            Not really sure, but this is how should work this feature Fredo?
                            Daniel S
                            cantfollow2.skp
                              DIEGO-RODRIGUEZ
                              Hi FREDO
                              I have drawn some models for you to teste the loft plugins
                              you need other models?
                              http://img8.imageshack.us/img8/870/sinttulo1ta.jpg
                              Sin tรญtulo.skp
                                Panga
                                Hi Fredo,
                                As promised, I attach to this post some test files in order you can evaluate your plugin with terrain work.
                                The first file (road test.skp), show you one of my principal process in order to make roads, and the boring step of cleaning the faces outside the original contours after using the sandbox...I weld all the contours of the road, but I think you'll have to create somme edges in order to divide the whole road in parts.
                                The second file are classic contours for terrain.
                                Hope it will help you to test your plugin.
                                Regards.
                                Road test.skp
                                Terrain test.skp
                                  Rainie
                                  When it is released. This was just a teaser. ๐Ÿ˜‰
                                  Hi, Thanks Thom for your very quick reply..Thanks!
                                    gofrez
                                    When i've seen this plugin i falled down the chair!! Amazing Fredo!!
                                    Frez
                                      Daniel S
                                      Here I make another quick test for loft feature. Itยดs simple but y really want to know if it would work in this cases.
                                      Daniel S
                                      Pencil for loft.skp
                                        robert111
                                        i like this plugin, but i dont see link to dowload it
                                        can anyone have link for this good plugin??
                                        • soloS Offline
                                          See title, it's a 'Preview', the plugin is still under construction and is not yet available.
                                          • H Offline
                                            Howard leslie
                                            Fredo,
                                            Looks really good.
                                            See attached file - a question for both you Fredo and TIG
                                            The Demo video shows clicking of 3 or 4 seperate lines.
                                            Will it be able to skin the attached file - a closed (welded) single polyline ???
                                            or would it have to be broken up into 3 or 4 seperate polylines first ???
                                            Maybe one of TIGs Extrude Tools can handle closed polylines like the attached file ???
                                            This would be really useful and a feature I'd request if this Script doesn't do it already
                                            (or if TIGs Extrude Tool doesn't already do it).
                                            Regards
                                            Howard L'
                                            BoatHull_Half.skp
                                            • 65
                                            • 66
                                            • 3 / 66
