    1.3k Posts 300 Posters 3.1m Views 298 Watching
      What speeds up thing greatly is if when you load the bitmaps you sort the pixels by colour, and then draw each colour in bulk.
      I load each bitmap for each toolbar button into a hash with the colour as key and the value as an array of point3d objects. Note that I merge all buttons into one hash.
      This means that if you are careful about your icon creation and use a palette of fewer colours you increase performance. A little bit pre-processing required, but the bulk drawing makes up for it many times over.
      • fredo6F
        One more video, on the possibility to borrow contours from within components....
          ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ˜„
          • EscapeArtistE
            EscapeArtist
            That last process vid you just posted would be a great time saver all by itself. I'm trying to think of something creative to offer as a sample, but you've covered pretty much what I'd use already.
            • EarthMoverE
              EarthMover
              Bloody genius! I'd swear I was looking a video from Rhino or Bonzai!!! ๐Ÿ‘ ๐Ÿ‘
              Content Creator at Skapeup
                On the last example, the curve can make a loop on the same plan?
                If yes,there is an automatic clean of the complex auto-intersect skin resulting?
                • soloS
                  oooh, good thinking.
                  Would it make a torus shape?
                  try this.skp
                    A Torus is easily made using the built-in FollowMe tool or even my EEbyLathe - BUT Fredo's new tool seems far more powerful, and so it should be able to do much greater things ๐ŸŽ‰
                    We await in anticipation...
                    • soloS
                      Okay, let's up the ante.
                      and this.skp
                        Daniel S
                        For loft along path you always show two faces or surface and a path...
                        It will be possible to select more faces?
                        Something like this image that I found:
                        https://forum.solidworks.com/servlet/JiveServlet/downloadImage/2-149439-7018/450-194/3-25-2010+9-53-54+AM.png
                        And I attach some models to see if they work with loft along path.
                        Daniel S
                        loft along path tests.skp
                        • bagateloB
                          bagatelo
                          [attachment=0:23rqfyk7]<!-- ia0 -->Contour components.gif<!-- ia0 -->[/attachment:23rqfyk7]
                          This remember solidworks. Non destructive work can be very interesting. And if can be possible to make smooth junctions.
                          Fredo, never doubt: WE LOVE YOU!!!
                            driven
                            hi Fredo,
                            if you need a mac tester...
                            this is a simple version of something I can't get any of the other tools to manage easily, but maybe it's me...
                            low-poly version of with a simplified path and face
                            cantfollow.skp
                              Daniel S
                              I donยดt know how to explain it in english, but you follow and rotate. So if curviloft works with closed paths and you can select more than 2 faces you will need to make something like the attachment.
                              Not really sure, but this is how should work this feature Fredo?
                              Daniel S
                              cantfollow2.skp
                                DIEGO-RODRIGUEZ
                                Hi FREDO
                                I have drawn some models for you to teste the loft plugins
                                you need other models?
                                http://img8.imageshack.us/img8/870/sinttulo1ta.jpg
                                Sin tรญtulo.skp
                                • P
                                  Panga
                                  Hi Fredo,
                                  As promised, I attach to this post some test files in order you can evaluate your plugin with terrain work.
                                  The first file (road test.skp), show you one of my principal process in order to make roads, and the boring step of cleaning the faces outside the original contours after using the sandbox...I weld all the contours of the road, but I think you'll have to create somme edges in order to divide the whole road in parts.
                                  The second file are classic contours for terrain.
                                  Hope it will help you to test your plugin.
                                  Regards.
                                  Road test.skp
                                  Terrain test.skp
                                    Rainie
                                    When it is released. This was just a teaser. ๐Ÿ˜‰
                                    Hi, Thanks Thom for your very quick reply..Thanks!
                                    • G
                                      gofrez
                                      When i've seen this plugin i falled down the chair!! Amazing Fredo!!
                                      Frez
                                        Daniel S
                                        Here I make another quick test for loft feature. Itยดs simple but y really want to know if it would work in this cases.
                                        Daniel S
                                        Pencil for loft.skp
                                          robert111
                                          i like this plugin, but i dont see link to dowload it
                                          can anyone have link for this good plugin??
                                          • soloS
                                            See title, it's a 'Preview', the plugin is still under construction and is not yet available.
                                            • 65
                                            • 66
                                            • 3 / 66
