    1.3k Posts 300 Posters 3.3m Views 298 Watching
    • soloS
      Okay, let's up the ante.
      and this.skp
        Daniel S
        For loft along path you always show two faces or surface and a path...
        It will be possible to select more faces?
        Something like this image that I found:
        https://forum.solidworks.com/servlet/JiveServlet/downloadImage/2-149439-7018/450-194/3-25-2010+9-53-54+AM.png
        And I attach some models to see if they work with loft along path.
        Daniel S
        loft along path tests.skp
        • bagateloB
          bagatelo
          One more video, on the possibility to borrow contours from within components....
          [attachment=0:23rqfyk7]<!-- ia0 -->Contour components.gif<!-- ia0 -->[/attachment:23rqfyk7]
          This remember solidworks. Non destructive work can be very interesting. And if can be possible to make smooth junctions.
          Fredo, never doubt: WE LOVE YOU!!!
            driven
            hi Fredo,
            if you need a mac tester...
            this is a simple version of something I can't get any of the other tools to manage easily, but maybe it's me...
            low-poly version of with a simplified path and face
            cantfollow.skp
              Daniel S
              I don´t know how to explain it in english, but you follow and rotate. So if curviloft works with closed paths and you can select more than 2 faces you will need to make something like the attachment.
              Not really sure, but this is how should work this feature Fredo?
              Daniel S
              cantfollow2.skp
                DIEGO-RODRIGUEZ
                Hi FREDO
                I have drawn some models for you to teste the loft plugins
                you need other models?
                http://img8.imageshack.us/img8/870/sinttulo1ta.jpg
                Sin título.skp
                • P
                  Panga
                  Hi Fredo,
                  As promised, I attach to this post some test files in order you can evaluate your plugin with terrain work.
                  The first file (road test.skp), show you one of my principal process in order to make roads, and the boring step of cleaning the faces outside the original contours after using the sandbox...I weld all the contours of the road, but I think you'll have to create somme edges in order to divide the whole road in parts.
                  The second file are classic contours for terrain.
                  Hope it will help you to test your plugin.
                  Regards.
                  Road test.skp
                  Terrain test.skp
                    Rainie
                    When it is released. This was just a teaser. 😉
                    Hi, Thanks Thom for your very quick reply..Thanks!
                    • G
                      gofrez
                      When i've seen this plugin i falled down the chair!! Amazing Fredo!!
                      Frez
                        Daniel S
                        Here I make another quick test for loft feature. It´s simple but y really want to know if it would work in this cases.
                        Daniel S
                        Pencil for loft.skp
                          robert111
                          i like this plugin, but i dont see link to dowload it
                          can anyone have link for this good plugin??
                          • soloS
                            See title, it's a 'Preview', the plugin is still under construction and is not yet available.
                            • H
                              Howard leslie
                              Fredo,
                              Looks really good.
                              See attached file - a question for both you Fredo and TIG
                              The Demo video shows clicking of 3 or 4 seperate lines.
                              Will it be able to skin the attached file - a closed (welded) single polyline ???
                              or would it have to be broken up into 3 or 4 seperate polylines first ???
                              Maybe one of TIGs Extrude Tools can handle closed polylines like the attached file ???
                              This would be really useful and a feature I'd request if this Script doesn't do it already
                              (or if TIGs Extrude Tool doesn't already do it).
                              Regards
                              Howard L'
                              BoatHull_Half.skp
                              • H
                                heatsun
                                Realy cool, thank U for the sharing!!!
                                • W
                                  weizxwilliam
                                  Wooo. this is cool. it must be award for your amazing job 😄
                                  • fredo6F
                                    @diego-rodriguez said:
                                    Hi FREDO
                                    Diego
                                    Many thanks for the examples. Here is the results, in video (quickly done), but before a few remarks:
                                    • the script does not support Sweep (i.e. Loft along two paths)
                                    • when contours are borrowed from component, you have to do a manual selection, because SU does not let you select edges within and outside component at the same time.
                                    • Holes are not supported directly. You need to generate the loft surface for each contour, inner and outer (just imagine that you can have many holes, and that you cannot edit the inner part if the outer part is generated at the same time)
                                    • I am still struggling to understand how SU orient faces when generated them. So for the time being, junctions may be oriented up or down (this can anyway easily be fixed afterward with Orient Faces and Reverse Faces).
                                    1. the easy ones
                                    2. Loft along path with 2 tubes
                                    3. This one shows that the script has still an issue with the vertex matching. But this is a way to also show how to correct it by editing the vertex matching.
                                    4. Another loft along path
                                    5. Some skinning, one still with an issue (a bug in SU API for colinear edges)
                                    Sin título - Diego - curviloft.skp
                                      DIEGO-RODRIGUEZ
                                      fredo excellent.
                                      models if you need more let me know.
                                      "Fredo:- the script does not support Sweep (i.e. Loft along two paths)"
                                      perhaps the plugins of kilrill, you help.
                                      the uses a second paths who calls " pick pathface adjuste curve"
                                      a question.
                                      the interface (panel floating bar) could be programmed in html?
                                      perhaps more could be done similar to dialog boxes of sketchup
                                      regards
                                        From what I understand, the face direction depends in the direction the points are added. Clockwise or counter-clockwise.
                                        • G
                                          gofrez
                                          Great Dude! This is making the history of SU!
                                          • fredo6F
                                            Tom,
                                            That's the rule. But the question is about add_faces_from_mesh. Ruby seems to choose an orientation and then stick to it. But what is teh rule for the first orientation, because in 3D there is nothing like clockwise or anticlockwise if you do not have a reference vector. Is it the absolute Z_AXIS or the Z_AXIS of the view coordinates or something else?
