    [Plugin] Work Plane
    183 Posts 32 Posters 112.4k Views 32 Watching
    • TIGT Online
      Here's v2.3 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
      Glitch when 'Adjust'ing a 'Disk' more than once is now fixed,
      A new 'Hide/UnHide All' toggle option added to context-menu/tools-menu.
      • CadFatherC Offline
        CadFather
        TIG, at least give me the time to finish writing my post! 😲 😎
        • TIGT Online
          The cause of the 'Adjust Disk' glitch was obvious to me as soon as you reported it - a line of code was not copied between the normal 'Disk Maker' and the 'Adjusted-Disk Maker' methods - thus the newly 'Adjusted' 'Disk' wasn't given its 'disk' attribute, and therefore the 'Adjust' tool thought it was a 'Plane' and so it 'Adjusted' it accordingly [wrongly!]. Note that 'Adjust' might still fail on older 'Disks', that were made before the recent updates and that don't have a 'disk' attribute - if so you need to re-make them and they will then be OK.
          Pilou's Hide/UnHide [good] idea was also very simple to do - just a few lines of code switching the 'WORKPLANE' layer on/off...
          πŸ€“
            CadFather
            ..i see, that actually makes sense.. still that was fast..
            [speaking aside] ..and the day hasn't even started..!
            Thanks! πŸ‘ β˜€
              πŸ‘
              Seems this default will be a must πŸ˜‰
              • simon le bonS Offline
                simon le bon
                Dear Tig,
                I'm just trying this new tool which seems to me very interesting, first to build something multileveled, and else to build a part of the drawing with peculiar axes: "non orthogonal",or perpendicular to the screen with the model twisted in some obscure direction.
                Additionally it seems also to me that Your
                TIG_Flatten to Plane v1.1
                and also
                Fredo_Tools On Surface - v1.2 (with Contour Editor)
                can help a lot..
                I don't know if the problem I encounter with Tapper Tool which won't align guide lines with the WorkPlane grid is already referenced or not. But this kind of malfunction is diminishing the tool IMo
                [flash=720,480:2yk2jx2w]http://www.youtube.com/v/ByD0mjaPnIk[/flash:2yk2jx2w]
                My best wishes for the festivities,
                simon.
                • guanjinG Offline
                  guanjin
                  Not see how the other icon
                  I come from China, is to learn
                  • TIGT Online
                    [attachment=0:1rh50put]<!-- ia0 -->ζœͺ命名.jpg<!-- ia0 -->[/attachment:1rh50put]
                    What other icons ?
                    You can get additional tools' icons, but only IF you have those other scripts loading too...
                    • guanjinG Offline
                      guanjin
                      @tig said:
                      What other icons ?
                      To see pictures, there are four icons! Thank you!
                      • TIGT Online
                        The other two icons only appear if you also have clinesaxes.rb loading.
                        Get it here http://forums.sketchucation.com/viewtopic.php?p=273671#p273671 if you need them...
                        • guanjinG Offline
                          guanjin
                          Thank you TIG, find you, always quick to solve the problem! πŸ‘ πŸ‘ πŸ‘
                            mmm-sued
                            Sorry, but I can't get your plugin "Work Plane" working correct (Windows 7, Sketchup 8 - NOT Pro, only the free version). If I create a "New Plane" or a "New Disk", they always disappear, when I then try to use the pencil tool or any other drawing tool. Only the "New Protractor" works correct. What can I do?
                            • TIGT Online
                              When you make the new WorkPlane you pick points in 3d to define it, then the final prompt tells you to "press <Enter> OR to Double-click to Confirm the new WorkPlane" - otherwise you will exit without saving the change ! So you are not confirming the WorkPlane but you are selecting another tool which then skips making a WorkPlane !!! πŸ˜’
                                mmm-sued
                                Thanks a lot! Great Tool!
                                • jim smithJ Offline
                                  jim smith
                                  TIg,
                                  just wanted to thank you for the work plane plugin. I missed seeing it in 2010 and ran across it accidently while viewing a you tube tutorial.. Very very usefull timesaver. πŸ‘
                                  "Out of clutter find simplicity,
                                  from discord find harmony,
                                  In the middle of difficulty lies opportunity"
                                  Albert Einstein
                                  • JClementsJ Offline
                                    JClements
                                    I notice if I use the context menu on a selected working plane and choose Working Plane > Scale and then do a rescale, that the working plane becomes ungrouped.
                                    Is this intended?
                                    • TIGT Online
                                      Is this intended?
                                      Probably not πŸ˜’
                                      I'll test it, if I understand you workflow correctly...
                                      • TIGT Online
                                        If I use the context-menu WorkPlane > Scale, it scales the group as expected.
                                        If I then use the native 'Reset Scale' item off the context-menu it resets it to its original size.
                                        I assume this is the command to which you referred.
                                        It does NOT ungroup [explode] the contents.
                                        So, my version does it as expected, yours doesn't.
                                        Do you have any third party scripts loading that might mess with this πŸ˜•
                                          JClements
                                          Tig, the only other thing I didn't mention previously was after choosing Scale from the Context Menu, I grabbed a corner scale handle, dragged inward, and then typed a value in the VCB of .5
                                          • TIGT Online
                                            John
                                            For me that method works just fine too.
                                            So something is adrift between your setup and me [and most other users?]
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 7 / 10
