    [Plugin] Work Plane
    183 Posts 32 Posters 151.2k Views 32 Watching
      dedmin
      Why rectangle tool doesn't draw on the Workplane?
      • EarthMoverE Offline
        EarthMover
        Dedmin, check pages 5 & 6 of this thread. Rectangle issue has been covered there. πŸ˜‰
        Content Creator at Skapeup
          @dedmin said:
          Why rectangle tool doesn't draw on the WorkPlane?
          It's a known issue with Sketchup itself - it occurs on all faces in groups/instances that are not axial or planar through the origin - not just this tool.
          There is a 3pt rectangle tool that will work - see the earlier thread...
          We await a fix from Google...
            dedmin
            Sorry 😳 😳
              Maybe Hide in the Context Menu πŸ˜‰
              Adjust Protractor
              and why not a protractor "rectangular" πŸ˜„
              That becomes the Rolls Royce of Work Plane 😎
              • kenK Offline
                ken
                The new "Protractor" option is implemented better than I could even image. Again thanks so much.
                Now, I will be quite as a mouse as I will be using the brand new tools.
                Ken
                • CadFatherC Offline
                  CadFather
                  there may be a glitch in the adjust menu on disk - it worked once, then i got the settings for the rectangular grid instead
                    Here's v2.3 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                    Glitch when 'Adjust'ing a 'Disk' more than once is now fixed,
                    A new 'Hide/UnHide All' toggle option added to context-menu/tools-menu.
                      CadFather
                      TIG, at least give me the time to finish writing my post! 😲 😎
                        The cause of the 'Adjust Disk' glitch was obvious to me as soon as you reported it - a line of code was not copied between the normal 'Disk Maker' and the 'Adjusted-Disk Maker' methods - thus the newly 'Adjusted' 'Disk' wasn't given its 'disk' attribute, and therefore the 'Adjust' tool thought it was a 'Plane' and so it 'Adjusted' it accordingly [wrongly!]. Note that 'Adjust' might still fail on older 'Disks', that were made before the recent updates and that don't have a 'disk' attribute - if so you need to re-make them and they will then be OK.
                        Pilou's Hide/UnHide [good] idea was also very simple to do - just a few lines of code switching the 'WORKPLANE' layer on/off...
                        πŸ€“
                          CadFather
                          ..i see, that actually makes sense.. still that was fast..
                          [speaking aside] ..and the day hasn't even started..!
                          Thanks! πŸ‘ β˜€
                            πŸ‘
                            Seems this default will be a must πŸ˜‰
                            • simon le bonS Offline
                              simon le bon
                              Dear Tig,
                              I'm just trying this new tool which seems to me very interesting, first to build something multileveled, and else to build a part of the drawing with peculiar axes: "non orthogonal",or perpendicular to the screen with the model twisted in some obscure direction.
                              Additionally it seems also to me that Your
                              TIG_Flatten to Plane v1.1
                              and also
                              Fredo_Tools On Surface - v1.2 (with Contour Editor)
                              can help a lot..
                              I don't know if the problem I encounter with Tapper Tool which won't align guide lines with the WorkPlane grid is already referenced or not. But this kind of malfunction is diminishing the tool IMo
                              [flash=720,480:2yk2jx2w]http://www.youtube.com/v/ByD0mjaPnIk[/flash:2yk2jx2w]
                              My best wishes for the festivities,
                              simon.
                              • guanjinG Offline
                                guanjin
                                Not see how the other icon
                                  [attachment=0:1rh50put]<!-- ia0 -->ζœͺ命名.jpg<!-- ia0 -->[/attachment:1rh50put]
                                  What other icons ?
                                  You can get additional tools' icons, but only IF you have those other scripts loading too...
                                  • guanjinG Offline
                                    guanjin
                                    @tig said:
                                    What other icons ?
                                    To see pictures, there are four icons! Thank you!
                                      The other two icons only appear if you also have clinesaxes.rb loading.
                                      Get it here http://forums.sketchucation.com/viewtopic.php?p=273671#p273671 if you need them...
                                      • guanjinG Offline
                                        guanjin
                                        Thank you TIG, find you, always quick to solve the problem! πŸ‘ πŸ‘ πŸ‘
                                          mmm-sued
                                          Sorry, but I can't get your plugin "Work Plane" working correct (Windows 7, Sketchup 8 - NOT Pro, only the free version). If I create a "New Plane" or a "New Disk", they always disappear, when I then try to use the pencil tool or any other drawing tool. Only the "New Protractor" works correct. What can I do?
                                            When you make the new WorkPlane you pick points in 3d to define it, then the final prompt tells you to "press <Enter> OR to Double-click to Confirm the new WorkPlane" - otherwise you will exit without saving the change ! So you are not confirming the WorkPlane but you are selecting another tool which then skips making a WorkPlane !!! πŸ˜’
                                            • 7 / 10
