    [Plugin] Work Plane
    183 Posts 32 Posters 151.2k Views 32 Watching
    • CadFatherC Offline
      CadFather
      ..i see, that actually makes sense.. still that was fast..
      [speaking aside] ..and the day hasn't even started..!
      Thanks! πŸ‘ β˜€
        πŸ‘
        Seems this default will be a must πŸ˜‰
        • simon le bonS Offline
          simon le bon
          Dear Tig,
          I'm just trying this new tool which seems to me very interesting, first to build something multileveled, and else to build a part of the drawing with peculiar axes: "non orthogonal",or perpendicular to the screen with the model twisted in some obscure direction.
          Additionally it seems also to me that Your
          TIG_Flatten to Plane v1.1
          and also
          Fredo_Tools On Surface - v1.2 (with Contour Editor)
          can help a lot..
          I don't know if the problem I encounter with Tapper Tool which won't align guide lines with the WorkPlane grid is already referenced or not. But this kind of malfunction is diminishing the tool IMo
          [flash=720,480:2yk2jx2w]http://www.youtube.com/v/ByD0mjaPnIk[/flash:2yk2jx2w]
          My best wishes for the festivities,
          simon.
          • guanjinG Offline
            guanjin
            Not see how the other icon
              [attachment=0:1rh50put]<!-- ia0 -->ζœͺ命名.jpg<!-- ia0 -->[/attachment:1rh50put]
              What other icons ?
              You can get additional tools' icons, but only IF you have those other scripts loading too...
              • guanjinG Offline
                guanjin
                @tig said:
                What other icons ?
                To see pictures, there are four icons! Thank you!
                  The other two icons only appear if you also have clinesaxes.rb loading.
                  Get it here http://forums.sketchucation.com/viewtopic.php?p=273671#p273671 if you need them...
                  • guanjinG Offline
                    guanjin
                    Thank you TIG, find you, always quick to solve the problem! πŸ‘ πŸ‘ πŸ‘
                      mmm-sued
                      Sorry, but I can't get your plugin "Work Plane" working correct (Windows 7, Sketchup 8 - NOT Pro, only the free version). If I create a "New Plane" or a "New Disk", they always disappear, when I then try to use the pencil tool or any other drawing tool. Only the "New Protractor" works correct. What can I do?
                        When you make the new WorkPlane you pick points in 3d to define it, then the final prompt tells you to "press <Enter> OR to Double-click to Confirm the new WorkPlane" - otherwise you will exit without saving the change ! So you are not confirming the WorkPlane but you are selecting another tool which then skips making a WorkPlane !!! πŸ˜’
                          mmm-sued
                          Thanks a lot! Great Tool!
                          • jim smithJ Offline
                            jim smith
                            TIg,
                            just wanted to thank you for the work plane plugin. I missed seeing it in 2010 and ran across it accidently while viewing a you tube tutorial.. Very very usefull timesaver. πŸ‘
                            "Out of clutter find simplicity,
                            from discord find harmony,
                            In the middle of difficulty lies opportunity"
                            Albert Einstein
                            • JClementsJ Offline
                              JClements
                              I notice if I use the context menu on a selected working plane and choose Working Plane > Scale and then do a rescale, that the working plane becomes ungrouped.
                              Is this intended?
                                Is this intended?
                                Probably not πŸ˜’
                                I'll test it, if I understand you workflow correctly...
                                  If I use the context-menu WorkPlane > Scale, it scales the group as expected.
                                  If I then use the native 'Reset Scale' item off the context-menu it resets it to its original size.
                                  I assume this is the command to which you referred.
                                  It does NOT ungroup [explode] the contents.
                                  So, my version does it as expected, yours doesn't.
                                  Do you have any third party scripts loading that might mess with this πŸ˜•
                                    JClements
                                    Tig, the only other thing I didn't mention previously was after choosing Scale from the Context Menu, I grabbed a corner scale handle, dragged inward, and then typed a value in the VCB of .5
                                      John
                                      For me that method works just fine too.
                                      So something is adrift between your setup and me [and most other users?]
                                      • sfto1S Offline
                                        sfto1
                                        Hello TIG,
                                        Is there a way to keep the grid from being deleted when I use the native delete guides tool?
                                        I started on this path with the SU teams's "Grid" plugin, and mitcorb suggested I try your work plane plugin v2.3. Am I doing something incorrectly that the work palane guides disappear when I use that native option?
                                        BTW, really cool plugin β˜€
                                          No.
                                          The native guide deleter erases ALL guides everywhere !
                                          Inside placed instances/groups and everywhere.
                                          They cannot be protected - evened 'locked' containers etc will lose content!
                                          There are alternatives to the native guide-deleter...
                                          Use one of those or accept that you cannot use the native guide-deleter OR that your WorkPlanes and any other object containing guides will loose them... πŸ˜’
                                          • sfto1S Offline
                                            sfto1
                                            Thanks TIG
                                            Cool plugin. I'll use some alternatives to preserve when needed.
                                            • 7 / 10
