    [Plugin] Work Plane
    183 Posts 32 Posters 133.1k Views 32 Watching
    • SiPieFaceS Offline
      SiPieFace
      I know this is an old thread but I've been trying to use Work Plane to be more efficient and accurate with my projects. It's a great plugin but I'm having a real issue changing the size of the Work Plane. Right-click into space just doesn't work for me, I get nothing at all. When I start Work Plane it merely allows me to select the 3 points and double-click to accept. I'm using SU2018 so wondered if this might be the issue?
        Sadly the right-click in empty-space to change settings no longer works.
        However, if you make a Workplane using the default values, then immediately Select it; its context-submenu then includes lots of extra options - use its 'Adjust' to change the size WH and grid XY...
          SiPieFace
          Ahh, that explains it. Thanks for the nod, I'll use that. This is such a useful plugin, is there any chance it'll get updated?
          • 6
          • 7
          • 8
          • 9
          • 10
          • 10 / 10
