    [Plugin] Work Plane
    183 Posts 32 Posters 157.7k Views 32 Watching
    • kenK
      ken
      The new "Protractor" option is implemented better than I could even image. Again thanks so much.
      Now, I will be quite as a mouse as I will be using the brand new tools.
      Ken
      • CadFatherC
        CadFather
        there may be a glitch in the adjust menu on disk - it worked once, then i got the settings for the rectangular grid instead
          Here's v2.3 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
          Glitch when 'Adjust'ing a 'Disk' more than once is now fixed,
          A new 'Hide/UnHide All' toggle option added to context-menu/tools-menu.
          • CadFatherC
            CadFather
            TIG, at least give me the time to finish writing my post! 😲 😎
              The cause of the 'Adjust Disk' glitch was obvious to me as soon as you reported it - a line of code was not copied between the normal 'Disk Maker' and the 'Adjusted-Disk Maker' methods - thus the newly 'Adjusted' 'Disk' wasn't given its 'disk' attribute, and therefore the 'Adjust' tool thought it was a 'Plane' and so it 'Adjusted' it accordingly [wrongly!]. Note that 'Adjust' might still fail on older 'Disks', that were made before the recent updates and that don't have a 'disk' attribute - if so you need to re-make them and they will then be OK.
              Pilou's Hide/UnHide [good] idea was also very simple to do - just a few lines of code switching the 'WORKPLANE' layer on/off...
              • CadFatherC
                CadFather
                ..i see, that actually makes sense.. still that was fast..
                [speaking aside] ..and the day hasn't even started..!
                Thanks! 👍 ☀
                  Seems this default will be a must 😉
                  • simon le bonS
                    simon le bon
                    Dear Tig,
                    I'm just trying this new tool which seems to me very interesting, first to build something multileveled, and else to build a part of the drawing with peculiar axes: "non orthogonal",or perpendicular to the screen with the model twisted in some obscure direction.
                    Additionally it seems also to me that Your
                    TIG_Flatten to Plane v1.1
                    and also
                    Fredo_Tools On Surface - v1.2 (with Contour Editor)
                    can help a lot..
                    I don't know if the problem I encounter with Tapper Tool which won't align guide lines with the WorkPlane grid is already referenced or not. But this kind of malfunction is diminishing the tool IMo
                    [flash=720,480:2yk2jx2w]http://www.youtube.com/v/ByD0mjaPnIk[/flash:2yk2jx2w]
                    My best wishes for the festivities,
                    simon.
                    • guanjinG
                      guanjin
                      Not see how the other icon
                        [attachment=0:1rh50put]<!-- ia0 -->未命名.jpg<!-- ia0 -->[/attachment:1rh50put]
                        What other icons ?
                        You can get additional tools' icons, but only IF you have those other scripts loading too...
                        • guanjinG
                          guanjin
                          @tig said:
                          What other icons ?
                          To see pictures, there are four icons! Thank you!
                            The other two icons only appear if you also have clinesaxes.rb loading.
                            Get it here http://forums.sketchucation.com/viewtopic.php?p=273671#p273671 if you need them...
                            • guanjinG
                              guanjin
                              Thank you TIG, find you, always quick to solve the problem! 👍 👍 👍
                                mmm-sued
                                Sorry, but I can't get your plugin "Work Plane" working correct (Windows 7, Sketchup 8 - NOT Pro, only the free version). If I create a "New Plane" or a "New Disk", they always disappear, when I then try to use the pencil tool or any other drawing tool. Only the "New Protractor" works correct. What can I do?
                                  When you make the new WorkPlane you pick points in 3d to define it, then the final prompt tells you to "press <Enter> OR to Double-click to Confirm the new WorkPlane" - otherwise you will exit without saving the change ! So you are not confirming the WorkPlane but you are selecting another tool which then skips making a WorkPlane !!! 😒
                                    mmm-sued
                                    Thanks a lot! Great Tool!
                                    • jim smithJ
                                      jim smith
                                      TIg,
                                      just wanted to thank you for the work plane plugin. I missed seeing it in 2010 and ran across it accidently while viewing a you tube tutorial.. Very very usefull timesaver. 👍
                                      "Out of clutter find simplicity,
                                      from discord find harmony,
                                      In the middle of difficulty lies opportunity"
                                      Albert Einstein
                                      • JClementsJ
                                        JClements
                                        I notice if I use the context menu on a selected working plane and choose Working Plane > Scale and then do a rescale, that the working plane becomes ungrouped.
                                        Is this intended?
                                          Is this intended?
                                          Probably not 😒
                                          I'll test it, if I understand you workflow correctly...
                                            If I use the context-menu WorkPlane > Scale, it scales the group as expected.
                                            If I then use the native 'Reset Scale' item off the context-menu it resets it to its original size.
                                            I assume this is the command to which you referred.
                                            It does NOT ungroup [explode] the contents.
                                            So, my version does it as expected, yours doesn't.
                                            Do you have any third party scripts loading that might mess with this 😕
                                            • 7 / 10
