    [Plugin] Work Plane
    183 Posts 32 Posters 148.5k Views 32 Watching
      @dedmin said:
      Why rectangle tool doesn't draw on the WorkPlane?
      It's a known issue with Sketchup itself - it occurs on all faces in groups/instances that are not axial or planar through the origin - not just this tool.
      There is a 3pt rectangle tool that will work - see the earlier thread...
      We await a fix from Google...
        dedmin
        Sorry 😳 😳
          Maybe Hide in the Context Menu πŸ˜‰
          Adjust Protractor
          and why not a protractor "rectangular" πŸ˜„
          That becomes the Rolls Royce of Work Plane 😎
          • kenK Offline
            ken
            The new "Protractor" option is implemented better than I could even image. Again thanks so much.
            Now, I will be quite as a mouse as I will be using the brand new tools.
            Ken
            • CadFatherC Offline
              CadFather
              there may be a glitch in the adjust menu on disk - it worked once, then i got the settings for the rectangular grid instead
                Here's v2.3 http://forums.sketchucation.com/viewtopic.php?p=274345#p274345
                Glitch when 'Adjust'ing a 'Disk' more than once is now fixed,
                A new 'Hide/UnHide All' toggle option added to context-menu/tools-menu.
                  CadFather
                  TIG, at least give me the time to finish writing my post! 😲 😎
                    The cause of the 'Adjust Disk' glitch was obvious to me as soon as you reported it - a line of code was not copied between the normal 'Disk Maker' and the 'Adjusted-Disk Maker' methods - thus the newly 'Adjusted' 'Disk' wasn't given its 'disk' attribute, and therefore the 'Adjust' tool thought it was a 'Plane' and so it 'Adjusted' it accordingly [wrongly!]. Note that 'Adjust' might still fail on older 'Disks', that were made before the recent updates and that don't have a 'disk' attribute - if so you need to re-make them and they will then be OK.
                    Pilou's Hide/UnHide [good] idea was also very simple to do - just a few lines of code switching the 'WORKPLANE' layer on/off...
                    πŸ€“
                      CadFather
                      ..i see, that actually makes sense.. still that was fast..
                      [speaking aside] ..and the day hasn't even started..!
                      Thanks! πŸ‘ β˜€
                        πŸ‘
                        Seems this default will be a must πŸ˜‰
                        • simon le bonS Offline
                          simon le bon
                          Dear Tig,
                          I'm just trying this new tool which seems to me very interesting, first to build something multileveled, and else to build a part of the drawing with peculiar axes: "non orthogonal",or perpendicular to the screen with the model twisted in some obscure direction.
                          Additionally it seems also to me that Your
                          TIG_Flatten to Plane v1.1
                          and also
                          Fredo_Tools On Surface - v1.2 (with Contour Editor)
                          can help a lot..
                          I don't know if the problem I encounter with Tapper Tool which won't align guide lines with the WorkPlane grid is already referenced or not. But this kind of malfunction is diminishing the tool IMo
                          [flash=720,480:2yk2jx2w]http://www.youtube.com/v/ByD0mjaPnIk[/flash:2yk2jx2w]
                          My best wishes for the festivities,
                          simon.
                          • guanjinG Offline
                            guanjin
                            Not see how the other icon
                              [attachment=0:1rh50put]<!-- ia0 -->ζœͺ命名.jpg<!-- ia0 -->[/attachment:1rh50put]
                              What other icons ?
                              You can get additional tools' icons, but only IF you have those other scripts loading too...
                              • guanjinG Offline
                                guanjin
                                @tig said:
                                What other icons ?
                                To see pictures, there are four icons! Thank you!
                                  The other two icons only appear if you also have clinesaxes.rb loading.
                                  Get it here http://forums.sketchucation.com/viewtopic.php?p=273671#p273671 if you need them...
                                  • guanjinG Offline
                                    guanjin
                                    Thank you TIG, find you, always quick to solve the problem! πŸ‘ πŸ‘ πŸ‘
                                      mmm-sued
                                      Sorry, but I can't get your plugin "Work Plane" working correct (Windows 7, Sketchup 8 - NOT Pro, only the free version). If I create a "New Plane" or a "New Disk", they always disappear, when I then try to use the pencil tool or any other drawing tool. Only the "New Protractor" works correct. What can I do?
                                        When you make the new WorkPlane you pick points in 3d to define it, then the final prompt tells you to "press <Enter> OR to Double-click to Confirm the new WorkPlane" - otherwise you will exit without saving the change ! So you are not confirming the WorkPlane but you are selecting another tool which then skips making a WorkPlane !!! πŸ˜’
                                          mmm-sued
                                          Thanks a lot! Great Tool!
                                          • jim smithJ Offline
                                            jim smith
                                            TIg,
                                            just wanted to thank you for the work plane plugin. I missed seeing it in 2010 and ran across it accidently while viewing a you tube tutorial.. Very very usefull timesaver. πŸ‘
                                            "Out of clutter find simplicity,
                                            from discord find harmony,
                                            In the middle of difficulty lies opportunity"
                                            Albert Einstein
                                            • 7 / 10
