    [Plugin] Work Plane
    183 Posts 32 Posters 157.7k Views 32 Watching
    • sfto1S
      sfto1
      Hello TIG,
      Is there a way to keep the grid from being deleted when I use the native delete guides tool?
      I started on this path with the SU teams's "Grid" plugin, and mitcorb suggested I try your work plane plugin v2.3. Am I doing something incorrectly that the work palane guides disappear when I use that native option?
      BTW, really cool plugin ☀
      • TIGT
        No.
        The native guide deleter erases ALL guides everywhere !
        Inside placed instances/groups and everywhere.
        They cannot be protected - evened 'locked' containers etc will lose content!
        There are alternatives to the native guide-deleter...
        Use one of those or accept that you cannot use the native guide-deleter OR that your WorkPlanes and any other object containing guides will loose them... 😒
        • sfto1S
          sfto1
          Thanks TIG
          Cool plugin. I'll use some alternatives to preserve when needed.
          • P
            paulckruger
            Perhaps my couple of weeks of playing renders me to much a newbie to understand this plugin. 😞
            I found it when searching for a way to correct a model with two objects where in the process of building them they "went astray" of the original plane so that when I try to print them on my Printerbot they are askew.
            How can I use this plugin to align the bottom plane of both objects so they are flat on the new plane?
            I created a disk that lays flat on the XY axis and can clearly see the objects are not lying flat but are slightly tilted. I spend a lot of time trying to manually rotate to get things aligned on the xy axis but just cannot seem to get there.
            Is there a simple explanation or instruction on how to select a component and then make sure it's bottom face is aligned FLAT to the new disk? Then repeat for the second object so their bottom faces are both exactly on the same plane?
            This is a screen cap showing the edge-on of the new disk plane and the skew of the components relative to the disk.
            Be gentle with me...I am not yet familiar enough with Sketchup for someone to just assume I already know all the functions.
            Thanks in advance your your help guys ( and gals ) ☀
              Paul, you don't need a plugin of any sort to align the bottoms of the objects. You can do this with just the Move tool. Select the object you wish to move and get the Move tool. Grab the selection at a point along the bottom and start moving it in the blue direction. Press and hold Shift to lock the direction of the Move and then move the cursor to the bottom of the other object. You can also use the up or down cursor keys to lock the direction although I'm partial to using the Shift key because it's only one key for locking direction and it works on off axis moves, too.
              • mitcorbM
                mitcorb
                I thought some of his components were skewed from the vertical?
                  They might be and of course that'll require other stuff. I didn't want to assmue, though.
                  • T
                    tspco
                    I installed this today, it might be more useful, if the units were not feet, perhaps some variables, feet, inches or feet+inches. Granted is is a simple matter to convert the units, but in the case of 16 inches, I feel 1'4" might be better that 1.33333.
                    Just my 2¢ worth.
                    SU make 2017, /Twilight Render Hobby
                    Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                    • BoxB
                      I think you will find it is using the units of the model. Try setting the model units to Fractional or whichever suits your model.
                      • T
                        tspco
                        I use feet and inches, I tried putting in 1'4" and got an error.
                          You're kind of vague. What was the error message?
                          Where were you trying to enter your 1'4"? If you look at the first post of the thread you'll see that the default size of the grid is 50' x 50'. The instructions are given there for changing it.
                          • T
                            tspco
                            Screenshots...
                            When I try to change the work grid plane settings, I get the error. Bottom line is you cannot use anything but feet or decimals of feet in the plugins current state. For a 16" on center, I either use 16" or 1'4" not 1.3333 (feet).
                            • TIGT
                              My WorkPlane currently takes input as a float number and converts it into a length.
                              You cannot input fractional inches etc.
                              However, I'll look at updating it as things have moved on and it's easy enough to enable now...
                              • T
                                tspco
                                Thanks Tig
                                • TIGT
                                  I now have a working version that takes each and every units format input [5' 6 1/2" etc !]
                                  I'll publish it later when I get some time to encrypt it etc for the PluginStore...
                                  • TIGT
                                    Here's v2.4 http://sketchucation.com/forums/viewtopic.php?p=274345#p274345
                                    It has been Module-ized.
                                    Inputs can now be in any units/format:
                                    1'6", 1 1/2", 1000mm, 100cm, 10m, 1234.5 etc...
                                    There is also some more 'future-proofing' behind the scenes...
                                    Get the latest version from the PluginStore... http://sketchucation.com/pluginstore?pln=WorkPlane
                                    • TIGT
                                      Here's v2.5 http://sketchucation.com/forums/viewtopic.php?p=274345#p274345
                                      It has some minor cosmetic tweaks.
                                      As recently updated, inputs can now be in any units/format:
                                      • K
                                        kaas
                                        Hello TIG,
                                        I'm trying out Workplane in SU2014. I think it isn't always working as intended. For instance when drawing a rectangle and sometimes even simple lines on a angular workplane - they are drawn on the world-xy plane instead.
                                        greetings, Max
                                        • TIGT
                                          Do you make the WorkPlane big enough to draw onto ?
                                          It does NOT constrain the input points from other tools onto the plane, if they are OUTSIDE of the WorkPlane's perimeter... 😕
                                          • K
                                            kaas
                                            Workplane is big enough indeed. See attached file.
                                            workplane.skp
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 8 / 10
