    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.1m Views 254 Watching
      saturne45
      Very great job.....
        Cyberdactyl
        @thomthom said:
        Did you model everything in SU?
        Got a screenshot of the SU model in default colours?
        Yes, all SU using Indigo. I posted it back in November.
        • jo-keJ Offline
          jo-ke
          @robert111 said:
          i need make good carpet with this plugin , but i dont have good setting for good carpet.
          I think it is a good tool for shaggy carpets:
          I've made this one with that great plugin:
          http://www.zz7.de
            tomasz
            @tak2hata said:
            assign fur_parameter to current material.
            add ruby definition for any exporters.
            Thanks! Will certainly test it!
            Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
              tue.tue
              http://www.imageupload.sketchupthai.com/images/90843954647566768582_thumb.jpg
              http://www.imageupload.sketchupthai.com/images/25219015849218734229.jpg
              • N Offline
                noom_jakri
                wow,Amazing plugin
                  cronicash
                  It builds really fast. So efficient yet looks so good.
                  Kinda prefer to the displacement method. Trying to work with leaf (clipped) and arch at the mo to get a seed head on random stalks..
                  Just a quick instance and baked for 5mins. Thanks heaps solo. 😉
                  http://i271.photobucket.com/albums/jj125/cronicash/grass.jpg
                  Edit: Easy as! (maybe a bit too higher population of seed lol, too easy to get kinda carried away)
                  Another 5mins
                  http://i271.photobucket.com/albums/jj125/cronicash/grass2.jpg
                  A bit taxing with the clipping otherwise effective....
                  Rendered using thea...
                  • EscapeArtistE Offline
                    EscapeArtist
                    Those grassland/prairie scenes look nice.
                    • RichardR Offline
                      Richard
                      Yeah that praire grass is amazing, would love to see your settings for that!
                      [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                      • PixeroP Offline
                        Pixero
                        Would it be possible to have it make "guide hairs" that external renderers then could fill the inbetweens with a preset number of strands without bogging down SketchUp? Thats how most fur solutions work in other apps AFAIK.
                        Another possibility is to be able to "style/comb" the guide hairs/strands.
                        Maybe with splines as guides and Thomthoms coming vertex edit plugin?
                        (A "Combing" function request, Thomthom.) 😉
                        Edit, splines CAN be used as fur if you make it a component instance. But that way you'll edit all strands if you edit one. An option to use your own shape without it having to be a component maybe?
                        (I'm talking about guide strands here.)
                        • RichardR Offline
                          Richard
                          Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
                          • F Offline
                            fabprera
                            How I download the plugin? Help me please
                              Hi Fabio,
                              Plugins are generally attached to the end of the very first post in the topic.
                              • massimoM Offline
                                massimo Moderator
                                Really nice images cronicash. 👍
                                • PixeroP Offline
                                  Pixero
                                  Thats not what I was after.
                                  Styling fur/hair/grass is a way of...styling it to suite the geometry like combing hair on a head.
                                  "Guide hairs" is a way of using a few strands too control placement and direction and styling of a at render time full dense fur/grass/hair.
                                  Here are two links to other fur solutions that explains combing:
                                  http://www.worley.com/E/Products/sasquatch/combing.html
                                  http://www.joealter.com/newSite/combing.htm
                                    Ruturaj
                                    Really nice plugin ......
                                    Very nice
                                    Thanks .........
                                    Thanks,
                                    RuturaJ
                                      AcesHigh
                                      @xrok1 said:
                                      i knew i should have popped that before it got out of hand! 😲
                                      who would have ever imagined fur for SU?????????????????????????????
                                      a very hairy nipple?? 😄 😄
                                      • E Offline
                                        ENG. YASEEN
                                        I Made This By Fur Plugin 😍
                                        http://i567.photobucket.com/albums/ss118/ALGALY/XYZ4Studioin4.jpg
                                        Thx tak2hata
                                        My Website:
                                        http://xyz4studio.blogspot.com/
                                          adityas
                                          What am I suppose to do after making fun with this tools?
                                          Should I cry or just shout to tell the author, "THIS IS A SUPER DUPER MARVELOUS PLUGIN!!!"
                                          Damn good... simple but... (I cant't explain with words).
                                          • mariochaM Offline
                                            mariocha
                                            Hey many, many thanks man ! impressive plugin.
                                            After all, some still think art is easier on grass 😆
                                            %(#008000)[Mario C.
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 32
                                            • 33
                                            • 7 / 33
