    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • EscapeArtistE
      EscapeArtist
      Those grassland/prairie scenes look nice.
      • RichardR
        Richard
        Yeah that praire grass is amazing, would love to see your settings for that!
        BUILTBRAND.COM.AU
        • PixeroP
          Pixero
          Would it be possible to have it make "guide hairs" that external renderers then could fill the inbetweens with a preset number of strands without bogging down SketchUp? Thats how most fur solutions work in other apps AFAIK.
          Another possibility is to be able to "style/comb" the guide hairs/strands.
          Maybe with splines as guides and Thomthoms coming vertex edit plugin?
          (A "Combing" function request, Thomthom.) πŸ˜‰
          Edit, splines CAN be used as fur if you make it a component instance. But that way you'll edit all strands if you edit one. An option to use your own shape without it having to be a component maybe?
          (I'm talking about guide strands here.)
          • RichardR
            Richard
            Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
            BUILTBRAND.COM.AU
            • F
              fabprera
              How I download the plugin? Help me please
              • GaieusG
                Hi Fabio,
                Plugins are generally attached to the end of the very first post in the topic.
                • massimoM
                  massimo Moderator
                  Really nice images cronicash. πŸ‘
                  • PixeroP
                    Pixero
                    Thats not what I was after.
                    Styling fur/hair/grass is a way of...styling it to suite the geometry like combing hair on a head.
                    "Guide hairs" is a way of using a few strands too control placement and direction and styling of a at render time full dense fur/grass/hair.
                    Here are two links to other fur solutions that explains combing:
                    http://www.worley.com/E/Products/sasquatch/combing.html
                    http://www.joealter.com/newSite/combing.htm
                      Ruturaj
                      Really nice plugin ......
                      Very nice
                      Thanks .........
                      Thanks,
                      RuturaJ
                        AcesHigh
                        @xrok1 said:
                        i knew i should have popped that before it got out of hand! 😲
                        who would have ever imagined fur for SU?????????????????????????????
                        a very hairy nipple?? πŸ˜„ πŸ˜„
                        • E
                          ENG. YASEEN
                          I Made This By Fur Plugin 😍
                          http://i567.photobucket.com/albums/ss118/ALGALY/XYZ4Studioin4.jpg
                          😎 πŸ‘
                          Thx tak2hata
                          My Website:
                          http://xyz4studio.blogspot.com/
                            adityas
                            What am I suppose to do after making fun with this tools?
                            Should I cry or just shout to tell the author, "THIS IS A SUPER DUPER MARVELOUS PLUGIN!!!"
                            Damn good... simple but... (I cant't explain with words).
                            • mariochaM
                              mariocha
                              Hey many, many thanks man ! impressive plugin.
                              After all, some still think art is easier on grass πŸ˜†
                              %(#008000)[Mario C.
                              • RichardR
                                Richard
                                Sorry mate I understand now! Yes certainly an option to force specs easier than it certainly could be without work! Though that said this is the first we have seen of this plug so who knows, good idea though!!!! πŸ˜„
                                BUILTBRAND.COM.AU
                                • T
                                  tak2hata
                                  Hi, All.
                                  I updated make fur plugin version to 1.3a(test version).
                                  Because I changed the format of the preset, it is not compatible with the one before.
                                  Please warn you.
                                  Thanks.
                                  by TAK2HATA
                                  • EscapeArtistE
                                    EscapeArtist
                                    Just keeps getting better!
                                      Daniel S
                                      Thank you for the update tak2hata!
                                      Perhaps in next versions you can put all the options in a submenu? Something like the attachment.
                                      Daniel S
                                        Why metric and imperial? Why not just deal with the units in the way that the model is?
                                        • T
                                          tak2hata
                                          Hi,Daniel.
                                          I Changed menu items into sub menu named "Fur_v1_3".
                                          Hi,Thomas.
                                          Because I think it easy to test both imperial and metric.
                                          I am not accustomed to the imperial.
                                          I will corrects it in future version.
                                          Thanks for your advice.
                                          by TAK2HATA
                                            The Numeric, Float and String class has some nice methods that let you deal with units in the user's locale and in the current model's units.
                                            • 32
                                            • 33
                                            • 7 / 33
