    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
    • F Offline
      ferrosoa
      incredible ... its real, fur in sketchup ... ... god job for author, thx 😎
        Cyberdactyl
        This changes the whole ballgame boys and girls.
        When I modeled the dragonfly below a few months ago, I painstakingly modeled and 'hand placed' pretty much every hair. This plug-in will save me TONS of time next I need fine filaments or random leaves.
        http://img.photobucket.com/albums/v606/Cyberdactyl/DETAIL3.jpg
        Thanks for sharing! 👍
          Did you model everything in SU?
          Got a screenshot of the SU model in default colours?
            saturne45
            Very great job.....
              Cyberdactyl
              Yes, all SU using Indigo. I posted it back in November.
              • jo-keJ Offline
                jo-ke
                @robert111 said:
                i need make good carpet with this plugin , but i dont have good setting for good carpet.
                I think it is a good tool for shaggy carpets:
                I've made this one with that great plugin:
                http://www.zz7.de
                  tomasz
                  @tak2hata said:
                  assign fur_parameter to current material.
                  add ruby definition for any exporters.
                  Thanks! Will certainly test it!
                    tue.tue
                    http://www.imageupload.sketchupthai.com/images/90843954647566768582_thumb.jpg
                    http://www.imageupload.sketchupthai.com/images/25219015849218734229.jpg
                    • N Offline
                      noom_jakri
                      wow,Amazing plugin
                        cronicash
                        It builds really fast. So efficient yet looks so good.
                        Kinda prefer to the displacement method. Trying to work with leaf (clipped) and arch at the mo to get a seed head on random stalks..
                        Just a quick instance and baked for 5mins. Thanks heaps solo. 😉
                        http://i271.photobucket.com/albums/jj125/cronicash/grass.jpg
                        Edit: Easy as! (maybe a bit too higher population of seed lol, too easy to get kinda carried away)
                        Another 5mins
                        http://i271.photobucket.com/albums/jj125/cronicash/grass2.jpg
                        A bit taxing with the clipping otherwise effective....
                        Rendered using thea...
                        • EscapeArtistE Offline
                          EscapeArtist
                          Those grassland/prairie scenes look nice.
                          • RichardR Offline
                            Richard
                            Yeah that praire grass is amazing, would love to see your settings for that!
                            BUILTBRAND.COM.AU
                            • PixeroP Offline
                              Pixero
                              Would it be possible to have it make "guide hairs" that external renderers then could fill the inbetweens with a preset number of strands without bogging down SketchUp? Thats how most fur solutions work in other apps AFAIK.
                              Another possibility is to be able to "style/comb" the guide hairs/strands.
                              Maybe with splines as guides and Thomthoms coming vertex edit plugin?
                              (A "Combing" function request, Thomthom.) 😉
                              Edit, splines CAN be used as fur if you make it a component instance. But that way you'll edit all strands if you edit one. An option to use your own shape without it having to be a component maybe?
                              (I'm talking about guide strands here.)
                              • RichardR Offline
                                Richard
                                Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
                                BUILTBRAND.COM.AU
                                • F Offline
                                  fabprera
                                  How I download the plugin? Help me please
                                    Hi Fabio,
                                    Plugins are generally attached to the end of the very first post in the topic.
                                    • massimoM Offline
                                      massimo Moderator
                                      Really nice images cronicash. 👍
                                      • PixeroP Offline
                                        Pixero
                                        Thats not what I was after.
                                        Styling fur/hair/grass is a way of...styling it to suite the geometry like combing hair on a head.
                                        "Guide hairs" is a way of using a few strands too control placement and direction and styling of a at render time full dense fur/grass/hair.
                                        Here are two links to other fur solutions that explains combing:
                                        http://www.worley.com/E/Products/sasquatch/combing.html
                                        http://www.joealter.com/newSite/combing.htm
                                          Ruturaj
                                          Really nice plugin ......
                                          Very nice
                                          Thanks .........
                                          Thanks,
                                          RuturaJ
                                            AcesHigh
                                            @xrok1 said:
                                            i knew i should have popped that before it got out of hand! 😲
                                            who would have ever imagined fur for SU?????????????????????????????
                                            a very hairy nipple?? 😄 😄
                                            • 32
                                            • 33
                                            • 7 / 33
