    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      Cyberdactyl
      This changes the whole ballgame boys and girls.
      When I modeled the dragonfly below a few months ago, I painstakingly modeled and 'hand placed' pretty much every hair. This plug-in will save me TONS of time next I need fine filaments or random leaves.
      http://img.photobucket.com/albums/v606/Cyberdactyl/DETAIL3.jpg
      Thanks for sharing! 👍
        Did you model everything in SU?
        Got a screenshot of the SU model in default colours?
          saturne45
          Very great job.....
            Cyberdactyl
            Yes, all SU using Indigo. I posted it back in November.
            • jo-keJ Offline
              jo-ke
              @robert111 said:
              i need make good carpet with this plugin , but i dont have good setting for good carpet.
              I think it is a good tool for shaggy carpets:
              I've made this one with that great plugin:
              http://www.zz7.de
                tomasz
                @tak2hata said:
                assign fur_parameter to current material.
                add ruby definition for any exporters.
                Thanks! Will certainly test it!
                  tue.tue
                  http://www.imageupload.sketchupthai.com/images/90843954647566768582_thumb.jpg
                  http://www.imageupload.sketchupthai.com/images/25219015849218734229.jpg
                  • N Offline
                    noom_jakri
                    wow,Amazing plugin
                      cronicash
                      It builds really fast. So efficient yet looks so good.
                      Kinda prefer to the displacement method. Trying to work with leaf (clipped) and arch at the mo to get a seed head on random stalks..
                      Just a quick instance and baked for 5mins. Thanks heaps solo. 😉
                      http://i271.photobucket.com/albums/jj125/cronicash/grass.jpg
                      Edit: Easy as! (maybe a bit too higher population of seed lol, too easy to get kinda carried away)
                      Another 5mins
                      http://i271.photobucket.com/albums/jj125/cronicash/grass2.jpg
                      A bit taxing with the clipping otherwise effective....
                      Rendered using thea...
                      • EscapeArtistE Offline
                        EscapeArtist
                        Those grassland/prairie scenes look nice.
                        • RichardR Offline
                          Richard
                          Yeah that praire grass is amazing, would love to see your settings for that!
                          BUILTBRAND.COM.AU
                          • PixeroP Offline
                            Pixero
                            Would it be possible to have it make "guide hairs" that external renderers then could fill the inbetweens with a preset number of strands without bogging down SketchUp? Thats how most fur solutions work in other apps AFAIK.
                            Another possibility is to be able to "style/comb" the guide hairs/strands.
                            Maybe with splines as guides and Thomthoms coming vertex edit plugin?
                            (A "Combing" function request, Thomthom.) 😉
                            Edit, splines CAN be used as fur if you make it a component instance. But that way you'll edit all strands if you edit one. An option to use your own shape without it having to be a component maybe?
                            (I'm talking about guide strands here.)
                            • RichardR Offline
                              Richard
                              Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
                              BUILTBRAND.COM.AU
                              • F Offline
                                fabprera
                                How I download the plugin? Help me please
                                  Hi Fabio,
                                  Plugins are generally attached to the end of the very first post in the topic.
                                  • massimoM Offline
                                    massimo Moderator
                                    Really nice images cronicash. 👍
                                    • PixeroP Offline
                                      Pixero
                                      Thats not what I was after.
                                      Styling fur/hair/grass is a way of...styling it to suite the geometry like combing hair on a head.
                                      "Guide hairs" is a way of using a few strands too control placement and direction and styling of a at render time full dense fur/grass/hair.
                                      Here are two links to other fur solutions that explains combing:
                                      http://www.worley.com/E/Products/sasquatch/combing.html
                                      http://www.joealter.com/newSite/combing.htm
                                        Ruturaj
                                        Really nice plugin ......
                                        Very nice
                                        Thanks .........
                                        Thanks,
                                        RuturaJ
                                          AcesHigh
                                          @xrok1 said:
                                          i knew i should have popped that before it got out of hand! 😲
                                          who would have ever imagined fur for SU?????????????????????????????
                                          a very hairy nipple?? 😄 😄
                                          • E Offline
                                            ENG. YASEEN
                                            I Made This By Fur Plugin 😍
                                            http://i567.photobucket.com/albums/ss118/ALGALY/XYZ4Studioin4.jpg
                                            Thx tak2hata
                                            My Website:
                                            http://xyz4studio.blogspot.com/
                                            • 32
                                            • 33
                                            • 7 / 33
