    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      robert111
      i need make good carpet with this plugin , but i dont have good setting for good carpet.
      • MALAISEM Offline
        MALAISE
        Thx really amazing
        MALAISE
          lapx
          Does it work for version 6.4 pro? N 😍 ever mind, just got the lastest version! Fantastic!
            yes works with SU V6 ☀
            • F Offline
              ferrosoa
              incredible ... its real, fur in sketchup ... ... god job for author, thx 😎
                Cyberdactyl
                This changes the whole ballgame boys and girls.
                When I modeled the dragonfly below a few months ago, I painstakingly modeled and 'hand placed' pretty much every hair. This plug-in will save me TONS of time next I need fine filaments or random leaves.
                http://img.photobucket.com/albums/v606/Cyberdactyl/DETAIL3.jpg
                Thanks for sharing! 👍
                  Did you model everything in SU?
                  Got a screenshot of the SU model in default colours?
                    saturne45
                    Very great job.....
                      Cyberdactyl
                      Yes, all SU using Indigo. I posted it back in November.
                      • jo-keJ Offline
                        jo-ke
                        I think it is a good tool for shaggy carpets:
                        I've made this one with that great plugin:
                        http://www.zz7.de
                          tomasz
                          @tak2hata said:
                          assign fur_parameter to current material.
                          add ruby definition for any exporters.
                          Thanks! Will certainly test it!
                            tue.tue
                            http://www.imageupload.sketchupthai.com/images/90843954647566768582_thumb.jpg
                            http://www.imageupload.sketchupthai.com/images/25219015849218734229.jpg
                            • N Offline
                              noom_jakri
                              wow,Amazing plugin
                                cronicash
                                It builds really fast. So efficient yet looks so good.
                                Kinda prefer to the displacement method. Trying to work with leaf (clipped) and arch at the mo to get a seed head on random stalks..
                                Just a quick instance and baked for 5mins. Thanks heaps solo. 😉
                                http://i271.photobucket.com/albums/jj125/cronicash/grass.jpg
                                Edit: Easy as! (maybe a bit too higher population of seed lol, too easy to get kinda carried away)
                                Another 5mins
                                http://i271.photobucket.com/albums/jj125/cronicash/grass2.jpg
                                A bit taxing with the clipping otherwise effective....
                                Rendered using thea...
                                • EscapeArtistE Offline
                                  EscapeArtist
                                  Those grassland/prairie scenes look nice.
                                  • RichardR Offline
                                    Richard
                                    Yeah that praire grass is amazing, would love to see your settings for that!
                                    BUILTBRAND.COM.AU
                                    • PixeroP Offline
                                      Pixero
                                      Would it be possible to have it make "guide hairs" that external renderers then could fill the inbetweens with a preset number of strands without bogging down SketchUp? Thats how most fur solutions work in other apps AFAIK.
                                      Another possibility is to be able to "style/comb" the guide hairs/strands.
                                      Maybe with splines as guides and Thomthoms coming vertex edit plugin?
                                      (A "Combing" function request, Thomthom.) 😉
                                      Edit, splines CAN be used as fur if you make it a component instance. But that way you'll edit all strands if you edit one. An option to use your own shape without it having to be a component maybe?
                                      (I'm talking about guide strands here.)
                                      • RichardR Offline
                                        Richard
                                        Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
                                        BUILTBRAND.COM.AU
                                        • F Offline
                                          fabprera
                                          How I download the plugin? Help me please
                                            Hi Fabio,
                                            Plugins are generally attached to the end of the very first post in the topic.
                                            • 32
                                            • 33
                                            • 7 / 33
