    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • RichardR
      Richard
      Yeah that praire grass is amazing, would love to see your settings for that!
      BUILTBRAND.COM.AU
      • PixeroP
        Pixero
        Would it be possible to have it make "guide hairs" that external renderers then could fill the inbetweens with a preset number of strands without bogging down SketchUp? Thats how most fur solutions work in other apps AFAIK.
        Another possibility is to be able to "style/comb" the guide hairs/strands.
        Maybe with splines as guides and Thomthoms coming vertex edit plugin?
        (A "Combing" function request, Thomthom.) πŸ˜‰
        Edit, splines CAN be used as fur if you make it a component instance. But that way you'll edit all strands if you edit one. An option to use your own shape without it having to be a component maybe?
        (I'm talking about guide strands here.)
        • RichardR
          Richard
          Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
          BUILTBRAND.COM.AU
          • F
            fabprera
            How I download the plugin? Help me please
            • GaieusG
              Hi Fabio,
              Plugins are generally attached to the end of the very first post in the topic.
              • massimoM
                massimo Moderator
                Really nice images cronicash. πŸ‘
                • PixeroP
                  Pixero
                  Thats not what I was after.
                  Styling fur/hair/grass is a way of...styling it to suite the geometry like combing hair on a head.
                  "Guide hairs" is a way of using a few strands too control placement and direction and styling of a at render time full dense fur/grass/hair.
                  Here are two links to other fur solutions that explains combing:
                  http://www.worley.com/E/Products/sasquatch/combing.html
                  http://www.joealter.com/newSite/combing.htm
                    Ruturaj
                    Really nice plugin ......
                    Very nice
                    Thanks .........
                    Thanks,
                    RuturaJ
                      AcesHigh
                      @xrok1 said:
                      i knew i should have popped that before it got out of hand! 😲
                      who would have ever imagined fur for SU?????????????????????????????
                      a very hairy nipple?? πŸ˜„ πŸ˜„
                      • E
                        ENG. YASEEN
                        I Made This By Fur Plugin 😍
                        http://i567.photobucket.com/albums/ss118/ALGALY/XYZ4Studioin4.jpg
                        😎 πŸ‘
                        Thx tak2hata
                        My Website:
                        http://xyz4studio.blogspot.com/
                          adityas
                          What am I suppose to do after making fun with this tools?
                          Should I cry or just shout to tell the author, "THIS IS A SUPER DUPER MARVELOUS PLUGIN!!!"
                          Damn good... simple but... (I cant't explain with words).
                          • mariochaM
                            mariocha
                            Hey many, many thanks man ! impressive plugin.
                            After all, some still think art is easier on grass πŸ˜†
                            %(#008000)[Mario C.
                            • RichardR
                              Richard
                              Sorry mate I understand now! Yes certainly an option to force specs easier than it certainly could be without work! Though that said this is the first we have seen of this plug so who knows, good idea though!!!! πŸ˜„
                              BUILTBRAND.COM.AU
                              • T
                                tak2hata
                                Hi, All.
                                I updated make fur plugin version to 1.3a(test version).
                                Because I changed the format of the preset, it is not compatible with the one before.
                                Please warn you.
                                Thanks.
                                by TAK2HATA
                                • EscapeArtistE
                                  EscapeArtist
                                  Just keeps getting better!
                                    Daniel S
                                    Thank you for the update tak2hata!
                                    Perhaps in next versions you can put all the options in a submenu? Something like the attachment.
                                    Daniel S
                                      Why metric and imperial? Why not just deal with the units in the way that the model is?
                                      • T
                                        tak2hata
                                        Hi,Daniel.
                                        I Changed menu items into sub menu named "Fur_v1_3".
                                        Hi,Thomas.
                                        Because I think it easy to test both imperial and metric.
                                        I am not accustomed to the imperial.
                                        I will corrects it in future version.
                                        Thanks for your advice.
                                        by TAK2HATA
                                          The Numeric, Float and String class has some nice methods that let you deal with units in the user's locale and in the current model's units.
                                          • T
                                            tak2hata
                                            Hi, Thomas.
                                            Thanks ! I'm searching for that method.
                                            by TAK2HATA
                                            • 32
                                            • 33
                                            • 7 / 33
