    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
    • C
      cronicash
      It builds really fast. So efficient yet looks so good.
      Kinda prefer to the displacement method. Trying to work with leaf (clipped) and arch at the mo to get a seed head on random stalks..
      Just a quick instance and baked for 5mins. Thanks heaps solo. πŸ˜‰
      http://i271.photobucket.com/albums/jj125/cronicash/grass.jpg
      Edit: Easy as! (maybe a bit too higher population of seed lol, too easy to get kinda carried away)
      Another 5mins
      http://i271.photobucket.com/albums/jj125/cronicash/grass2.jpg
      A bit taxing with the clipping otherwise effective....
      Rendered using thea...
      • EscapeArtistE
        EscapeArtist
        Those grassland/prairie scenes look nice.
        • RichardR
          Richard
          Yeah that praire grass is amazing, would love to see your settings for that!
          BUILTBRAND.COM.AU
          • PixeroP
            Pixero
            Would it be possible to have it make "guide hairs" that external renderers then could fill the inbetweens with a preset number of strands without bogging down SketchUp? Thats how most fur solutions work in other apps AFAIK.
            Another possibility is to be able to "style/comb" the guide hairs/strands.
            Maybe with splines as guides and Thomthoms coming vertex edit plugin?
            (A "Combing" function request, Thomthom.) πŸ˜‰
            Edit, splines CAN be used as fur if you make it a component instance. But that way you'll edit all strands if you edit one. An option to use your own shape without it having to be a component maybe?
            (I'm talking about guide strands here.)
            • RichardR
              Richard
              Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
              BUILTBRAND.COM.AU
              • F
                fabprera
                How I download the plugin? Help me please
                • GaieusG
                  Hi Fabio,
                  Plugins are generally attached to the end of the very first post in the topic.
                  • massimoM
                    massimo Moderator
                    Really nice images cronicash. πŸ‘
                    • PixeroP
                      Pixero
                      Thats not what I was after.
                      Styling fur/hair/grass is a way of...styling it to suite the geometry like combing hair on a head.
                      "Guide hairs" is a way of using a few strands too control placement and direction and styling of a at render time full dense fur/grass/hair.
                      Here are two links to other fur solutions that explains combing:
                      http://www.worley.com/E/Products/sasquatch/combing.html
                      http://www.joealter.com/newSite/combing.htm
                        Ruturaj
                        Really nice plugin ......
                        Very nice
                        Thanks .........
                        Thanks,
                        RuturaJ
                          AcesHigh
                          @xrok1 said:
                          i knew i should have popped that before it got out of hand! 😲
                          who would have ever imagined fur for SU?????????????????????????????
                          a very hairy nipple?? πŸ˜„ πŸ˜„
                          • E
                            ENG. YASEEN
                            I Made This By Fur Plugin 😍
                            http://i567.photobucket.com/albums/ss118/ALGALY/XYZ4Studioin4.jpg
                            😎 πŸ‘
                            Thx tak2hata
                            My Website:
                            http://xyz4studio.blogspot.com/
                              adityas
                              What am I suppose to do after making fun with this tools?
                              Should I cry or just shout to tell the author, "THIS IS A SUPER DUPER MARVELOUS PLUGIN!!!"
                              Damn good... simple but... (I cant't explain with words).
                              • mariochaM
                                mariocha
                                Hey many, many thanks man ! impressive plugin.
                                After all, some still think art is easier on grass πŸ˜†
                                %(#008000)[Mario C.
                                • RichardR
                                  Richard
                                  Sorry mate I understand now! Yes certainly an option to force specs easier than it certainly could be without work! Though that said this is the first we have seen of this plug so who knows, good idea though!!!! πŸ˜„
                                  BUILTBRAND.COM.AU
                                  • T
                                    tak2hata
                                    Hi, All.
                                    I updated make fur plugin version to 1.3a(test version).
                                    Because I changed the format of the preset, it is not compatible with the one before.
                                    Please warn you.
                                    Thanks.
                                    by TAK2HATA
                                    • EscapeArtistE
                                      EscapeArtist
                                      Just keeps getting better!
                                        Daniel S
                                        Thank you for the update tak2hata!
                                        Perhaps in next versions you can put all the options in a submenu? Something like the attachment.
                                        Daniel S
                                          Why metric and imperial? Why not just deal with the units in the way that the model is?
                                          • T
                                            tak2hata
                                            Hi,Daniel.
                                            I Changed menu items into sub menu named "Fur_v1_3".
                                            Hi,Thomas.
                                            Because I think it easy to test both imperial and metric.
                                            I am not accustomed to the imperial.
                                            I will corrects it in future version.
                                            Thanks for your advice.
                                            by TAK2HATA
                                            • 32
                                            • 33
                                            • 7 / 33
