    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.3m Views 254 Watching
      Did you model everything in SU?
      Got a screenshot of the SU model in default colours?
        saturne45
        Very great job.....
        • C
          Cyberdactyl
          Yes, all SU using Indigo. I posted it back in November.
          • jo-keJ
            jo-ke
            @robert111 said:
            i need make good carpet with this plugin , but i dont have good setting for good carpet.
            I think it is a good tool for shaggy carpets:
            I've made this one with that great plugin:
            http://www.zz7.de
            • T
              tomasz
              @tak2hata said:
              assign fur_parameter to current material.
              add ruby definition for any exporters.
              Thanks! Will certainly test it!
              • T
                tue.tue
                http://www.imageupload.sketchupthai.com/images/90843954647566768582_thumb.jpg
                http://www.imageupload.sketchupthai.com/images/25219015849218734229.jpg
                • N
                  noom_jakri
                  wow,Amazing plugin
                  • C
                    cronicash
                    It builds really fast. So efficient yet looks so good.
                    Kinda prefer to the displacement method. Trying to work with leaf (clipped) and arch at the mo to get a seed head on random stalks..
                    Just a quick instance and baked for 5mins. Thanks heaps solo. 😉
                    http://i271.photobucket.com/albums/jj125/cronicash/grass.jpg
                    Edit: Easy as! (maybe a bit too higher population of seed lol, too easy to get kinda carried away)
                    Another 5mins
                    http://i271.photobucket.com/albums/jj125/cronicash/grass2.jpg
                    A bit taxing with the clipping otherwise effective....
                    Rendered using thea...
                    • EscapeArtistE
                      EscapeArtist
                      Those grassland/prairie scenes look nice.
                      • RichardR
                        Richard
                        Yeah that praire grass is amazing, would love to see your settings for that!
                        BUILTBRAND.COM.AU
                        • PixeroP
                          Pixero
                          Would it be possible to have it make "guide hairs" that external renderers then could fill the inbetweens with a preset number of strands without bogging down SketchUp? Thats how most fur solutions work in other apps AFAIK.
                          Another possibility is to be able to "style/comb" the guide hairs/strands.
                          Maybe with splines as guides and Thomthoms coming vertex edit plugin?
                          (A "Combing" function request, Thomthom.) 😉
                          Edit, splines CAN be used as fur if you make it a component instance. But that way you'll edit all strands if you edit one. An option to use your own shape without it having to be a component maybe?
                          (I'm talking about guide strands here.)
                          • RichardR
                            Richard
                            Mate you can select the surface and make alternatives to fill the same space so that the components aren't all the same!
                            BUILTBRAND.COM.AU
                            • F
                              fabprera
                              How I download the plugin? Help me please
                              • GaieusG
                                Hi Fabio,
                                Plugins are generally attached to the end of the very first post in the topic.
                                • massimoM
                                  massimo Moderator
                                  Really nice images cronicash. 👍
                                  • PixeroP
                                    Pixero
                                    Thats not what I was after.
                                    Styling fur/hair/grass is a way of...styling it to suite the geometry like combing hair on a head.
                                    "Guide hairs" is a way of using a few strands too control placement and direction and styling of a at render time full dense fur/grass/hair.
                                    Here are two links to other fur solutions that explains combing:
                                    http://www.worley.com/E/Products/sasquatch/combing.html
                                    http://www.joealter.com/newSite/combing.htm
                                      Ruturaj
                                      Really nice plugin ......
                                      Very nice
                                      Thanks .........
                                      Thanks,
                                      RuturaJ
                                        AcesHigh
                                        @xrok1 said:
                                        i knew i should have popped that before it got out of hand! 😲
                                        who would have ever imagined fur for SU?????????????????????????????
                                        a very hairy nipple?? 😄 😄
                                        • E
                                          ENG. YASEEN
                                          I Made This By Fur Plugin 😍
                                          http://i567.photobucket.com/albums/ss118/ALGALY/XYZ4Studioin4.jpg
                                          Thx tak2hata
                                          My Website:
                                          http://xyz4studio.blogspot.com/
                                            adityas
                                            What am I suppose to do after making fun with this tools?
                                            Should I cry or just shout to tell the author, "THIS IS A SUPER DUPER MARVELOUS PLUGIN!!!"
                                            Damn good... simple but... (I cant't explain with words).
                                            • 32
                                            • 33
                                            • 7 / 33
