    ⚠️ Important | Libfredo 15.6a introduces important bugfixes for Fredo's Extensions Update
    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
    • jeff hammondJ Offline
      jeff hammond
      hey fredo
      i've come across an instance where v1.6 is freezing sketchup and 1.5 handles it just fine.. i'm not sure if the problem is in something i'm doing wrong, something mac specific, or what.
      i'll attach the .skp (v8).. the two faces i'm having problems with are the ones painted orange.
      thanks
      [edit -- removed file]
      [and maybe someone else can try this with jpp v1.6 on windows (or mac to see if it's repeatable for them as well)]
      dotdotdot
        baiduaiya
         thank you very much
          [IMPORTANT Version 1.6 has a big bug, causing a freeze of Sketchup in some situations. If you installed it, please move to JPP v1.7, which fixes the problem.]
          Indeed, I have just had to update JPP as I had freezing with a model. Many-manythanks, Fredo, for this excellent tool and the constant upgrades!
          πŸ‘
          • fredo6F Offline
            fredo6
            NEW RELEASE
            version 1.8a - 01 May 11: Better respect the offset distance in case where the surface is composed of faces with sharp angles. In V1.8, this works also when there is an imposed plane set by Ctrl-Arrow.
            See main post for download.
            Fredo
              NEW RELEASE
              Fredo
              πŸ‘ πŸ‘ πŸ˜„
                Ben Ritter
                Fredo6, thank you.
                  The JPP_Dir_17 folder is required?
                    I think not - as it contains nothing that's not already in the new 18 version ??
                    V18 works OK for me without v17... πŸ˜•
                      I got confused because the zip file contained the 1.7 files as well as the 1.8...
                      • fredo6F Offline
                        fredo6
                        Tom,
                        Are you sure? Which unzip program do you use?
                        It is true that I took a copy of the 1.7 zip file, emptied it, and then insert the 1.8 files. With Winzip, there is no problem. But it may not be true with other unzip utilities.
                        Fredo
                          driven
                          it's empty, but in there on the mac as well, Stuffit Expander...
                          john
                          • massimoM Offline
                            massimo Moderator
                            I use 7-zip and there is an empty JPP_Dir_17 folder once unzipped.
                            Oh and πŸ‘ πŸ‘ Fredo. πŸ˜„
                              I just used Windows to open the file. I don't use third party applications for zip files. No need.
                                Here's a screenshot of the current archive which I just opened in AlZip - the v1.7 folder IS still there... πŸ˜•Capture.PNG It also contains no files...
                                • H Offline
                                  hgdn
                                  Fredo6,
                                  Thanks so much for upgrading already useful toy!
                                  Have a nice day!
                                  • FrederikF Offline
                                    Frederik
                                    I see the same folder structure in WinZip v14.5...
                                    The JPP_Dir_17 is empty, but it's there...
                                    Any way... Thanks A LOT for this... πŸ˜„
                                    Cheers
                                    Kim Frederik
                                    • fredo6F Offline
                                      fredo6
                                      I just posted a 'fresh' zip file in the main post.
                                      Fredo
                                        I can confirm that the unwanted empty v17 folder is no longer in the zip file πŸ˜„
                                        • W Offline
                                          winnie70020807
                                          thanks~
                                            RizkySyahputra
                                            it's amazing πŸ‘ πŸ˜›
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
