    โš ๏ธ Important | Libfredo 15.6b introduces important bugfixes for Fredo's Extensions Update
    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
    • P Offline
      pmolsen
      Any chance of a new option to thicken a wall on both sides and delete the original wall in one step please?
      Would allow for example tracing the centreline of a complex wall from Google Earth, (eg. the walls of a house) then thickening it in one step.
      At present it is difficult to achieve. You have to thicken it in one direction by half, then thicken it the other way by the same amount. Problem is when you do the second step it leaves the original faces there, or at least the outlines, even if you specify delete original faces, meaning you wind up with a line down the centreline of the wall top and bottom which you then have to delete. For a long complex wall that can be painful.
      • P Offline
        pmolsen
        Another request please. An option to say borders on external faces EXCEPT THE BOTTOM FACE. When thickening a wall for example, a face on the bottom is often not wanted since it will be sitting flat on the Google Earth surface.
          Just don't select the bottom face.
          • mitcorbM Offline
            mitcorb
            Regarding your issue with Joint PushPull not staying orthogonal, Use either VectorPushPull or NormalPushPull as other options. You can predefine the path the PushPull will follow with a line segment or by example with a nearby line already in the model.
            That is, if I understood your problem.
            • P Offline
              pmolsen
              I do not know what you mean. I do not select the bottom face. I select the single vertical faces and push-pull them one direction. Faces get created all round and top and bottom. Without deselecting the selected faces I then push-pull them in the opposite direction. There is no way of not creating the bottom faces.
              But the problem is the outlines of the original faces remain on the top and bottom, along with numerous other lines generated by the push-pull. How do I prevent them?
              One thing I tried was pulling the faces in one direction with "Delete original faces" on and "No Borders". I then used the Cleanup plugin to delete all the orphaned edge lines from the original faces. I then reselected all the faces and tried to pull them in the opposite direction using Thickening and Borders on Outer Faces Only. It does not work.
              When you pull the wall in one direction using thickening, the original faces stay selected. If you then pull them in the other direction without deselecting them, they all move in the correct direction.
              If you do the first push-pull with no borders and delete original faces they do not stay selected. After you do the cleanup, you reselect them and try to pull them in the other direction but it does not work properly. Some of them pull the correct direction. Others pull the opposite way (the same direction as the first push-pull operation) meaning those parts of the wall end up offset from where they should be.
              • Y Offline
                yokaxi
                thanks
                • H Offline
                  hero719
                  โ˜€ ๐Ÿ‘ thk u sure!! i'm beginner.
                  • N Offline
                    Napper
                    I've been trying to extrude a wasching bowl by 12mm. The JPP crashes on me every time I do this no matter whether I try it on my XP machine at work or my Mac at home. Is this a bug, or too many faces?
                    Kind regards,
                    Napper
                    This washing bowl crashes JPP
                      Napper
                      It's an awkward shape to JPP...
                      I can't get a good result either ๐Ÿ˜•
                      Here's an alternative method...
                      As it's a solid you can use Jim Foltz's 'shell' @12mm, then temporarily hide the top of the original outer-shell, PushPull the top of the new solid inner-shell up ~50mm so it will pierce the outer-shell's top, intersect both groups' geometry together, and then erase the unwanted parts in them, explode the two groups together and re-group as one, smooth it... ๐Ÿ˜„WHB_Test2[TIGd].PNGWHB_Test2[TIGd].skp
                      • N Offline
                        Napper
                        Hi TIG,
                        this worked quite well, actually! I had to redo it, as I had given you the inner shell and needed an outer shell but that was good practice, actually... :smile: And along the way I got a new plugin, I had not been aware of as of yet. So, what I wanted to say is: THANK YOU!!! :smile:
                        Napper
                          JasonDoggart
                          Hi - thanks for all your hard work! This is such a useful, well designed tool!
                          • fredo6F Offline
                            fredo6
                            NEW RELEASE
                            version 1.6 - 22 Apr 11: bug fix - better respect of offset distance in case where the surface is composed of faces with sharp angles.
                            See main post for download.
                            Fredo
                            [Edit: I fixed the link to the download thread. TIG...]
                              SketchUpNoobie
                              NEW RELEASEbug fix - better respect of offset distance in case where the surface is composed of faces with sharp angles.
                              This will be great! Thanks! ๐Ÿ˜„ Have a cookie. ๐Ÿ˜‰ And...er...a beer. ๐Ÿ˜• Great combination. ๐Ÿคข
                              SketchUpNoobie: the complete noob in all things SketchUp.
                              • jeff hammondJ Offline
                                jeff hammond
                                nice!
                                works very well on my test case (which previously failed with v1.5).
                                thanks for the update!
                                dotdotdot
                                  dedmin
                                  SketchUp 8, Win7 32 - freezing too.
                                    driven
                                    hope this helps.
                                    Hi Fredo,
                                    Jeff's file fails on 10.5.8 as well, I'll attach the txt file
                                    john
                                      jeff hammond
                                      cool, thanks for testing fellas.
                                      dotdotdot
                                      • fredo6F Offline
                                        fredo6
                                        NEW RELEASE
                                        version 1.7a - 25 Apr 11: Fix a major bug of v1.6 which was causing a freeze of Sketchup in some situations.
                                        If you installed v1.6, It is strongly recommended to move to JPP 1.7
                                        Fredo
                                          driven
                                          hi Fredo,
                                          works on Jeff's skp on 10.5.8 now...
                                          cheers
                                          john
                                            jeff hammond
                                            works here now too.
                                            thank you
                                            dotdotdot
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 18
                                            • 19
                                            • 10 / 19
