    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
      I got confused because the zip file contained the 1.7 files as well as the 1.8...
      • fredo6F Offline
        Tom,
        Are you sure? Which unzip program do you use?
        It is true that I took a copy of the 1.7 zip file, emptied it, and then insert the 1.8 files. With Winzip, there is no problem. But it may not be true with other unzip utilities.
          driven
          it's empty, but in there on the mac as well, Stuffit Expander...
          • massimoM Offline
            massimo Moderator
            I use 7-zip and there is an empty JPP_Dir_17 folder once unzipped.
            Oh and πŸ‘ πŸ‘ Fredo. πŸ˜„
              I just used Windows to open the file. I don't use third party applications for zip files. No need.
                Here's a screenshot of the current archive which I just opened in AlZip - the v1.7 folder IS still there... πŸ˜•Capture.PNG It also contains no files...
                • H Offline
                  hgdn
                  Fredo6,
                  Thanks so much for upgrading already useful toy!
                  Have a nice day!
                  • FrederikF Offline
                    Frederik
                    I see the same folder structure in WinZip v14.5...
                    The JPP_Dir_17 is empty, but it's there...
                    Any way... Thanks A LOT for this... πŸ˜„
                    Cheers
                    Kim Frederik
                    • fredo6F Offline
                      I just posted a 'fresh' zip file in the main post.
                        I can confirm that the unwanted empty v17 folder is no longer in the zip file πŸ˜„
                        • W Offline
                          winnie70020807
                          thanks~
                            RizkySyahputra
                            it's amazing πŸ‘ πŸ˜›
                            • fredo6F Offline
                              NEW RELEASE
                              version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                              Note that the parameter "angle of influence" is no longer used.
                              See main post for download.
                                Thanks Fredo. Much appreciated πŸ‘
                                • bazB Offline
                                  baz
                                  Great stuff Fredo, thanks.
                                  Baz
                                  • fredo6F Offline
                                    NEW RELEASE
                                    version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                                    Version 2.0b also includes the Italian translation
                                      πŸ‘ πŸ‘
                                      • pep75P Offline
                                        pep75
                                        Fredo is the man!
                                        grtzzz
                                        Pep
                                        • N Offline
                                          niks
                                          just wanted to say THANK YOU πŸ‘Š
                                            BBLV
                                            Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
                                            Example of desired finished result:
                                            http://www.glumber.com/WoodTopSubpages/Details/EdgeTreatmentData/EdgeTreatmentSubPages/Edge_Profile_Photos/Roundover/HalfInchRoundover.jpg
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
