    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.0m Views 150 Watching
      The JPP_Dir_17 folder is required?
        I think not - as it contains nothing that's not already in the new 18 version ??
        V18 works OK for me without v17... πŸ˜•
          I got confused because the zip file contained the 1.7 files as well as the 1.8...
          • fredo6F Offline
            Tom,
            Are you sure? Which unzip program do you use?
            It is true that I took a copy of the 1.7 zip file, emptied it, and then insert the 1.8 files. With Winzip, there is no problem. But it may not be true with other unzip utilities.
              driven
              it's empty, but in there on the mac as well, Stuffit Expander...
              • massimoM Offline
                massimo Moderator
                I use 7-zip and there is an empty JPP_Dir_17 folder once unzipped.
                Oh and πŸ‘ πŸ‘ Fredo. πŸ˜„
                  I just used Windows to open the file. I don't use third party applications for zip files. No need.
                    Here's a screenshot of the current archive which I just opened in AlZip - the v1.7 folder IS still there... πŸ˜•Capture.PNG It also contains no files...
                    • H Offline
                      hgdn
                      Fredo6,
                      Thanks so much for upgrading already useful toy!
                      Have a nice day!
                      • FrederikF Offline
                        Frederik
                        I see the same folder structure in WinZip v14.5...
                        The JPP_Dir_17 is empty, but it's there...
                        Any way... Thanks A LOT for this... πŸ˜„
                        Cheers
                        Kim Frederik
                        • fredo6F Offline
                          I just posted a 'fresh' zip file in the main post.
                            I can confirm that the unwanted empty v17 folder is no longer in the zip file πŸ˜„
                            • W Offline
                              winnie70020807
                              thanks~
                                RizkySyahputra
                                it's amazing πŸ‘ πŸ˜›
                                • fredo6F Offline
                                  NEW RELEASE
                                  version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                                  Note that the parameter "angle of influence" is no longer used.
                                  See main post for download.
                                  • Rich O BrienR Online
                                    Thanks Fredo. Much appreciated πŸ‘
                                    • bazB Offline
                                      baz
                                      Great stuff Fredo, thanks.
                                      Baz
                                      • fredo6F Offline
                                        NEW RELEASE
                                        version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                                        Version 2.0b also includes the Italian translation
                                          πŸ‘ πŸ‘
                                          • pep75P Offline
                                            pep75
                                            Fredo is the man!
                                            grtzzz
                                            Pep
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
