    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.1m Views 150 Watching
      baiduaiya
       thank you very much
        [IMPORTANT Version 1.6 has a big bug, causing a freeze of Sketchup in some situations. If you installed it, please move to JPP v1.7, which fixes the problem.]
        Indeed, I have just had to update JPP as I had freezing with a model. Many-manythanks, Fredo, for this excellent tool and the constant upgrades!
        πŸ‘
        • fredo6F Offline
          NEW RELEASE
          version 1.8a - 01 May 11: Better respect the offset distance in case where the surface is composed of faces with sharp angles. In V1.8, this works also when there is an imposed plane set by Ctrl-Arrow.
          See main post for download.
            NEW RELEASE
            πŸ‘ πŸ‘ πŸ˜„
              Ben Ritter
              Fredo6, thank you.
                The JPP_Dir_17 folder is required?
                  I think not - as it contains nothing that's not already in the new 18 version ??
                  V18 works OK for me without v17... πŸ˜•
                    I got confused because the zip file contained the 1.7 files as well as the 1.8...
                    • fredo6F Offline
                      Tom,
                      Are you sure? Which unzip program do you use?
                      It is true that I took a copy of the 1.7 zip file, emptied it, and then insert the 1.8 files. With Winzip, there is no problem. But it may not be true with other unzip utilities.
                        driven
                        it's empty, but in there on the mac as well, Stuffit Expander...
                        • massimoM Offline
                          massimo Moderator
                          I use 7-zip and there is an empty JPP_Dir_17 folder once unzipped.
                          Oh and πŸ‘ πŸ‘ Fredo. πŸ˜„
                            I just used Windows to open the file. I don't use third party applications for zip files. No need.
                              Here's a screenshot of the current archive which I just opened in AlZip - the v1.7 folder IS still there... πŸ˜•Capture.PNG It also contains no files...
                              • H Offline
                                hgdn
                                Fredo6,
                                Thanks so much for upgrading already useful toy!
                                Have a nice day!
                                • FrederikF Offline
                                  Frederik
                                  I see the same folder structure in WinZip v14.5...
                                  The JPP_Dir_17 is empty, but it's there...
                                  Any way... Thanks A LOT for this... πŸ˜„
                                  Cheers
                                  Kim Frederik
                                  • fredo6F Offline
                                    I just posted a 'fresh' zip file in the main post.
                                      I can confirm that the unwanted empty v17 folder is no longer in the zip file πŸ˜„
                                      • W Offline
                                        winnie70020807
                                        thanks~
                                          RizkySyahputra
                                          it's amazing πŸ‘ πŸ˜›
                                          • fredo6F Offline
                                            NEW RELEASE
                                            version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                                            Note that the parameter "angle of influence" is no longer used.
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
