    Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
    368 Posts 150 Posters 2.2m Views 150 Watching
      driven
      But it may not be true with other unzip utilities.
      it's empty, but in there on the mac as well, Stuffit Expander...
      • massimoM
        massimo Moderator
        I use 7-zip and there is an empty JPP_Dir_17 folder once unzipped.
        Oh and πŸ‘ πŸ‘ Fredo. πŸ˜„
          I just used Windows to open the file. I don't use third party applications for zip files. No need.
            Here's a screenshot of the current archive which I just opened in AlZip - the v1.7 folder IS still there... πŸ˜•Capture.PNG It also contains no files...
            • H
              hgdn
              Fredo6,
              Thanks so much for upgrading already useful toy!
              Have a nice day!
              • FrederikF
                Frederik
                I see the same folder structure in WinZip v14.5...
                The JPP_Dir_17 is empty, but it's there...
                Any way... Thanks A LOT for this... πŸ˜„
                Cheers
                Kim Frederik
                • fredo6F
                  I just posted a 'fresh' zip file in the main post.
                    I can confirm that the unwanted empty v17 folder is no longer in the zip file πŸ˜„
                    • W
                      winnie70020807
                      thanks~
                        RizkySyahputra
                        it's amazing πŸ‘ πŸ˜›
                        • fredo6F
                          NEW RELEASE
                          version 2.0a - 16 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                          Note that the parameter "angle of influence" is no longer used.
                          See main post for download.
                            Thanks Fredo. Much appreciated πŸ‘
                            • bazB
                              baz
                              Great stuff Fredo, thanks.
                              Baz
                              • fredo6F
                                NEW RELEASE
                                version 2.0b - 17 Jul 11: Fixes for problems when applying to convoluted shapes. The issues were signaled by ThomThom.
                                Version 2.0b also includes the Italian translation
                                  πŸ‘ πŸ‘
                                  • pep75P
                                    pep75
                                    Fredo is the man!
                                    grtzzz
                                    Pep
                                    • N
                                      niks
                                      just wanted to say THANK YOU πŸ‘Š
                                      • B
                                        BBLV
                                        Will this plugin allow me to perform a 1/2" roundover on perpendicular intersecting edges?
                                        Example of desired finished result:
                                        http://www.glumber.com/WoodTopSubpages/Details/EdgeTreatmentData/EdgeTreatmentSubPages/Edge_Profile_Photos/Roundover/HalfInchRoundover.jpg
                                        • mitcorbM
                                          mitcorb
                                          Hi, BBLV:
                                          You will want to try Fredo's Round Corners, which will do that, plus chamfer, plus radiused corner and edges. Joint PushPull is a multiface simultaneous extrusion tool.
                                            rock1
                                            using this plugin when i push pull a curved surface i have to manually delete the original surface that was push pulled. is there any way that this plugin jointpushpulls just like a normal push. and not like a ctrl+pull that makes a new face? For example i just want this yellow extrusion to be a part of the whole solid.
                                            Signature removed by SCF Admin
                                            • 11
                                            • 12
                                            • 13
                                            • 18
                                            • 19
                                            • 11 / 19
