Joint Push Pull Classic (Old version) - v2.2a - 26 Apr 17
bug fix - better respect of offset distance in case where the surface is composed of faces with sharp angles.
nice!
works very well on my test case (which previously failed with v1.5).
thanks for the update! -
SketchUp 8, Win7 32 - freezing too.
cool, thanks for testing fellas.
NEW RELEASE
version 1.7a - 25 Apr 11: Fix a major bug of v1.6 which was causing a freeze of Sketchup in some situations.If you installed v1.6, It is strongly recommended to move to JPP 1.7
See main post for download.
hi Fredo,
works on Jeff's skp on 10.5.8 now...
cheers
works here now too.
thank you -
hey fredo
i've come across an instance where v1.6 is freezing sketchup and 1.5 handles it just fine.. i'm not sure if the problem is in something i'm doing wrong, something mac specific, or what.
i'll attach the .skp (v8).. the two faces i'm having problems with are the ones painted orange.
thanks[edit -- removed file]
[and maybe someone else can try this with jpp v1.6 on windows (or mac to see if it's repeatable for them as well)]
thank you very much -
[IMPORTANT Version 1.6 has a big bug, causing a freeze of Sketchup in some situations. If you installed it, please move to JPP v1.7, which fixes the problem.]
Indeed, I have just had to update JPP as I had freezing with a model. Many-manythanks, Fredo, for this excellent tool and the constant upgrades!
NEW RELEASE
version 1.8a - 01 May 11: Better respect the offset distance in case where the surface is composed of faces with sharp angles. In V1.8, this works also when there is an imposed plane set by Ctrl-Arrow.See main post for download.
NEW RELEASE
Fredo6, thank you.
The
JPP_Dir_17folder is required? -
@thomthom said:
The
JPP_Dir_17folder is required?I think not - as it contains nothing that's not already in the new 18 version ??
V18 works OK for me without v17...
I got confused because the zip file contained the 1.7 files as well as the 1.8...
Tom,
Are you sure? Which unzip program do you use?
It is true that I took a copy of the 1.7 zip file, emptied it, and then insert the 1.8 files. With Winzip, there is no problem. But it may not be true with other unzip utilities.
it's empty, but in there on the mac as well, Stuffit Expander...
I use 7-zip and there is an empty JPP_Dir_17 folder once unzipped.
Oh and
Fredo.
I just used Windows to open the file. I don't use third party applications for zip files. No need.
