    Rayscaper New Releases
    rayscaperrender
    171 Posts 9 Posters 1.2k Views 10 Watching
      Krass @Krass
      I'm getting used to this little program
      https://jskup.fr/wp-content/uploads/2025/02/2denoised.jpg
      https://jskup.fr/wp-content/uploads/2025/02/4denoised.jpg
      Krass
      • pixelcruncherP Offline
        Nice renders, especially the last one with the dinner plates.Nice use of DOF.
        S 1 Reply Last reply Reply Quote 0
          sashapepperspray @pixelcruncher
          @pixelcruncher Hello, I have downloaded sketchup 2025 and rayscaper doesn't work, it just says idle and doesn't render, (and do you have plans to incorporate sketchup's pbr materials into rayscaper's materials?) thanks
          pixelcruncherP 1 Reply Last reply Reply Quote 1
            Thomas was is aware of the incompatibility with 2025.
              Hey, Rayscaper users!
              Another release!
              Rayscaper 0.9.44 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
              What Changed?
              • Added support for SketchUp 2025.
              • Fixed energy loss in glass materials, which previously caused them to appear too dark.
              • Made asset thumbnail size configurable via the settings dialog.
              • Fixed reloading of SketchUp materials in Rayscaper.
              • Fixed light emission issues with HDRI environments.
              • Removed the 1000Γ—1000 pixel resolution limit for the free version.
              The asset thumbnail size is configured via the settings dialog:
              Help me build the community πŸ‘
              If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
              Happy Rendering!
                pixelcruncher Extension Creator @sashapepperspray
                @sashapepperspray said in Rayscaper New Releases:
                SketchUp 2025 is now supported in version 0.9.44 Beta. Let me know if there are any issues.
                I plan to map SketchUp's PBR material to Rayscaper's PBR material in one of the upcoming releases.
                Cheers,
                Thomas
                S 1 Reply Last reply Reply Quote 1
                  @pixelcruncher Thanks, it works
                    Krass
                    Hello, Pixelcruncher,
                    I updated the rbz from sketchucation, but I don't have this option to choose the thumbnail size.(very good improvement)
                    But I didn't uninstall rayscaper before reinstalling,
                    Krass
                    pixelcruncherP 1 Reply Last reply Reply Quote 0
                      Krass
                      that's fine, but I had to delete the rayscaper files in the hidden folders and in the sketchup plugins too. that's great, it'll let me look at the texture previews in detail on my laptop...., which has a high-definition screen, and I needed a magnifying glass...
                      Krass
                        Krass
                        and thank you for removing the pixel resolution limitation
                        Krass
                          @Krass said in Rayscaper New Releases:
                          Hey @Krass ,
                          Can you check the version you are running?
                          If it's 0.9.44 or higher, you should be able to configure the thumbnails via the settings dialog:
                          After updating the plugin in SketchUp, a restart of SketchUp is required. Otherwise, you will continue to run the older version of Rayscaper.
                          Regards,
                          Thomas
                            Krass
                            Hello, thomas,
                            sorry for the late reply
                            I will try to answer tonight
                            Krass
                            K 1 Reply Last reply Reply Quote 0
                              Krass @Krass
                              rays.png ![@Krass](image url)
                              I've stopped rendering for now, I'm stuck with this problematic project that I sent you screenshots of. These spots in the shadows
                              Krass
                                @Krass I'm looking into this, and the other bugs you reported. Will provide an update soon.
                                To confirm, is this the only scene where you see the black smears (taches)? Or are there other scenes where you are seeing the same thing?
                                Cheers,
                                Thomas
                                  Krass
                                  Helo Thomas,
                                  Yes, other renderings have the same problem, but I remember that this one down below didn't pose any problems even though the light sources were significantly less powerful. Maybe further away?
                                  https://jskup.fr/wp-content/uploads/2025/03/loft-cuisine-grise-web.jpg
                                  Krass
                                    Krass
                                    Hello, with better settings (transparent shadows) and a little cleaning (5 mn, photoshop), another render, I am very satisfied with it
                                    https://jskup.fr/wp-content/uploads/2025/04/rendu-9.48.jpg
                                    Krass
                                      Another release!
                                      Rayscaper 0.9.50 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
                                      What Changed?
                                      • Bring back the transparency shadows option for the glass material. This option makes the glass material invisible to
                                        shadow rays, allowing direct light to pass through the glass. This is useful for allowing direct light through glass
                                        in indoor scenes.
                                      • Add extra logging to help diagnose failed installations.
                                      • Cyrillic glyph support: The user interface now supports Cyrillic characters.
                                      • Improved pixel filtering: Fixed an issue where edges appeared overly jagged with the default settings.
                                      • Enhanced texture sliders: Scale and translation sliders now have more intuitive ranges.
                                      Happy Rendering!
                                      • majidM Offline
                                        majid
                                        Those renders are lovely!
                                          Krass
                                          Great!
                                          Thank you!
                                          Krass
                                          • majidM Offline
                                            majid @pixelcruncher
                                            @pixelcruncher I DMed you, do you mind checking it please?
                                            • 3 / 9
