    Rayscaper New Releases
    rayscaperrender
    540 Posts 13 Posters 248.8k Views 14 Watching
    • pixelcruncherP
      Hey, Rayscaper users!
      Another release!
      Rayscaper 0.9.36 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
      What Changed?
      Improvements
      Auto Focus
      • Add autofocus for DOF to the perspective camera. With autofocus, Rayscaper will automatically use the distance to the center 3D point in the rendered image as the focus distance (if possible).
      • Make the depth-of-field (DOF) blurriness easier to control. The range goes from 0 to 1, but if you need more blur for
        your scene, you can punch in a higher value directly in the slider text box (CTRL + click).
      • Make the depth-of-field blurriness slider logarithmic. This gives more control for low blur values.
      Bug Fixes
      • Fix the normal map strength control.
      • Fix a crash when exporting the scene to an archive.
        Spotlights with a falloff of zero would not render on the CPU. This release fixes that.
      Help me build the community πŸ‘
      I'm on Twitter (X) now: https://twitter.com/Rayscaper3d/ - Please follow the @Rayscaper3d that will help me grow the community and spread the word about Rayscaper! πŸ™
      If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is super motivating and will help me showcase its capabilities to new users.
      Happy Rendering!
      Reply Quote 2
      • pixelcruncherP
        Another release!
        Rayscaper 0.9.43 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
        What Changed?
        Improvements
        • Rayscaper now takes Windows monitor scaling into account. On scaled monitors, Rayscaper should display correctly
          without requiring manual user scaling. However, manual scaling is still an option if needed.
        • Use the same light sampling algorithm for CPU and GPU. This would sometimes cause render differences between CPU and
          GPU in complex lighting situations.
        • Generate better tangent vectors for normal mapping. This should improve the quality of normal mapping.
        • Rename the Disney material to PBR material.
        • Drop the thin sheet approximation for the Disney (PBR) material, it's not working correctly currently.
        • Drop the transmission color from the glass material.
        • In the PBR material, rename clearcoat gloss to clearcoat roughness for consistency with other materials.
        • Drop the environment light fake GI mode, it looks too weird to be useful.
        • Drop some render methods that are not that useful except for debugging ("Shading dP/dU", "Shading dP/dV", "Shading
          Incidence", "Shading Normals / No Bump").
        Bug Fixes
        • Fix a crash when double-clicking the save button in the GUI.
        • Fixed the saving of the DPI scale application setting.
        To avoid confusion, switching between CPU and GPU rendering doesn't happen anymore in the render tab but via the settings dialog (Menu > File > Settings).
        If you like Rayscaper, please share your renders (final or work-in-progress, it doesn't matter)! This is motivating and will help me showcase its capabilities to new users.
        Happy Rendering!
        • KrassK
          Krass
          Great !
          I'm testing your program, in the free version I discovered it when I was looking for free renderers for hobbyists and students and as twilight render disappeared, I came across Rayscaper.
          I'm very impressed: I'm familiar with v-ray, D5 render and Twinmotion, but your tool is great for beginners, but of course for pros at a very, very decent price.
          I'm in charge of a discord room on 3D rendering and plan to make tutorials for all those people who aren't into 3D rendering yet.
          Krass
          • pixelcruncherP
            @Krass I appreciate your interest in Rayscaper! Thanks.
            Glad to hear, I hope to build something that is very easy to use at a great price.
            Nice! Let me know how I can support you.
            Cheers,
            Thomas
            • KrassK
              Krass
              Hello,
              first interior render with GPU, 10 000 samples, took 20:50 mn. Still very noisy
              after external denoiser
              Krass
              Reply Quote 2
              • pixelcruncherP
                @Krass, those are nice renders!
                By external denoiser, do you mean the one in Rayscaper or something else?
                Pixel filtering can also help to get rid of some of the jagged lines:
                Happy Rendering!
                Thomas
                • KrassK
                  Krass
                  Hello,
                  another test where I changed the lights and set the gaussian filtering mode (radius 1.2 px) to, like antialias, correct the material problems.
                  I like the result, but I'd have to add some artificial lights to illuminate the scene.
                  https://jskup.fr/wp-content/uploads/2025/02/gaussian-1.2-denoise-denoise.png
                  Krass
                  • KrassK
                    Krass
                    I also applied a light coat of denoiser
                    Krass
                    • KrassK
                      Krass
                      By external denoiser I mean I use a program dedicated to denoising
                      Krass
                      • KrassK
                        Krass
                        an other render, this time I used Rascaper denoiser option
                        https://jskup.fr/wp-content/uploads/2025/02/filter-box-plus-RSCaper-denoiser.png
                        Krass
                        • KrassK
                          Krass
                          with rayscaper denoiser on
                          Krass
                          • pixelcruncherP
                            @Krass I like the result.
                            FYI, Rayscaper uses Intel's OpenImageDenoise (link). I think this is the same denoiser that Twilight Render uses in its denoise extension, so you should see comparable results.
                            • KrassK
                              Krass
                              final high res render, reduced in 1080 p and an other render, exterior
                              https://jskup.fr/wp-content/uploads/2025/02/rayscaper-1080p.jpg
                              https://jskup.fr/wp-content/uploads/2025/02/final2.jpg
                              Krass
                              KrassK 1 Reply Last reply
                              Reply Quote 2
                              • KrassK
                                Krass @Krass
                                I'm getting used to this little program
                                https://jskup.fr/wp-content/uploads/2025/02/2denoised.jpg
                                https://jskup.fr/wp-content/uploads/2025/02/4denoised.jpg
                                Krass
                                Reply Quote 2
                                • pixelcruncherP
                                  Nice renders, especially the last one with the dinner plates.Nice use of DOF.
                                  S 1 Reply Last reply
                                    sashapepperspray @pixelcruncher
                                    @pixelcruncher Hello, I have downloaded sketchup 2025 and rayscaper doesn't work, it just says idle and doesn't render, (and do you have plans to incorporate sketchup's pbr materials into rayscaper's materials?) thanks
                                      Thomas was is aware of the incompatibility with 2025.
                                      • pixelcruncherP
                                        Another release!
                                        Rayscaper 0.9.44 Beta is available in the SketchUcation store. More fixes and improvements. As always, I recommend upgrading to the latest version.
                                        What Changed?
                                        • Added support for SketchUp 2025.
                                        • Fixed energy loss in glass materials, which previously caused them to appear too dark.
                                        • Made asset thumbnail size configurable via the settings dialog.
                                        • Fixed reloading of SketchUp materials in Rayscaper.
                                        • Fixed light emission issues with HDRI environments.
                                        • Removed the 1000Γ—1000 pixel resolution limit for the free version.
                                        The asset thumbnail size is configured via the settings dialog:
                                        Happy Rendering!
                                        • pixelcruncherP
                                          pixelcruncher Extension Creator @sashapepperspray
                                          @sashapepperspray said in Rayscaper New Releases:
                                          SketchUp 2025 is now supported in version 0.9.44 Beta. Let me know if there are any issues.
                                          I plan to map SketchUp's PBR material to Rayscaper's PBR material in one of the upcoming releases.
                                          Cheers,
                                          Thomas
                                            @pixelcruncher Thanks, it works
                                            • 26
                                            • 27
                                            • 5 / 27
