    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 530.7k Views 75 Watching
    • E
      Efrado
      It is a pity.
      Thank you Thomas, and you too Tig.
      I will look forward to upgrade every thing.
      Thank you again and continue with the great job for us the sketchupers.
      • HornOxxH
        HornOxx
        Hi All, I was just playing something around this evening
        Some people succeed in lasering or engraving contours into a thick glass somehow - I have no idea how
        thay do it πŸ˜„ so this little exercise, to put the author Thomas Mann in thick glass, should just imitate this nice gimmick …
        such a great plugin - thanks for it!
        never trust a skinny cook
          Version 1.0.0
          See first post for more details: https://sketchucation.com/forums/viewtopic.php?f=323&t=31339#p275772
          • L
            Leander_Galanodel
            Hello!
            I just wanted to say THANK YOU for this great plugin! It saved me a lot of time. I could just import a heightmap instead of having to trace over a topographical map by hand. You saved me about a few weeks of work!
            If I ever upload my finished "project" to the 3D-Warehouse I will put a link to this plugin in the description.
            Thank you very much!!!
              SpookyChick1013
              2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:289:in each' C:/Users/Mistress Venhallyn/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:289:in trigger_event'
              C:/Users/Mistress Venhallyn/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:250:in block in create_dialog' SketchUp:1:in call'
              Having problems with this plugin not generating things Bitmap iin this case was 128 pixels on a side, no colorspace info, etc. Just the way it's supposed to be. I'm now stumped.
              Thanks in advance help is greatly appreciated
              https://kuromatsudriveyards.com
              Fo-su to tomo ni aran koto o...
                How about sharing the BMP file so we can see it and maybe help you out?
                  SpookyChick1013
                  Thanks Dave; I would, but .bmp extensions are not allowed. (just tried to upload the bmp as an attachment) Besides, I think the problem may be something tweaked with the plugin in regard to it's interaction with SU 2017. Since I updated a few days ago, the plugin keeps trying to make a second copy of the mesh at the time when it completes the first, and throws an error.
                  By the way, been meaning to say this for years, I like your signature.
                    How about uploading the BMP to DropBox and sharing the link.
                    What did you update a few days ago?
                    Thanks on the signature.
                      SpookyChick1013
                      I no longer do business with Dropbox. Long story.
                      I did solve the problem. Somehow an earlier version of the plugin got left behind when I updated it the other day. Removed it, no more problem.
                      Thanks anyway. πŸ˜„
                      • sketchartist023S
                        sketchartist023
                        Think I could get a working script of this for sketchup8? I cant seem to want to update because I have a LOT of plugins that work well together already πŸ˜›
                          I guess that thomthom's code uses Ruby API calls that are only available with newer versions of SketchUp.
                          So looks like v8 can't hack it ! Sorry.
                          • david_hD
                            david_h
                            So team: I haven't used this plugin in a while, and I may be doing something wrong. I am trying to make a mesh obviously. .. from a BMP of this image and all it does is stall out my Puter. What am I doing wrong? Something wrong iwth the image? not enough contrast?
                            thx,
                            p.s. I guess i could crop it to one panel and just repeat the model. Would that help?
                              Holey buckets! There's a lot to process there. I can imagine your puter needing to take a break now and then. It would help if you can reduce the size of the image to one panel although it might still be a lot of work. It'll certainly create a lot of geometry.
                              • david_hD
                                david_h
                                So i discovered. I got it to work with one panel, but the results were underwhelming. I think I will just use the image and a call it a day. 😲
                                Holy Buckets??? πŸ’š
                                  Probably a good idea to use the image as a texture. Reminds me of the curtain slides that would show during intermissions in the old black and white films.
                                  Holey if the water won't stay in. πŸ˜‰
                                  • david_hD
                                    david_h
                                    The texture is fine, using Photoshop of course. i was just playing to see if I could get it to work in 3D
                                    Thx,
                                    D
                                    There's a hole in the bucket. . .dear Liza.. .dear Liza. . .
                                    • T
                                      Triumfi
                                      The arrows for reducing pixels or polygons does not show, when i bring the cursor to the red line, any idea ??
                                        rayqian
                                        this is a great plugin for customize tiling texture, while the sketchup has no responding when I import a 500*500 pixel test BMP file as an image and run "mesh from bitmap", see the screenshot.
                                          Quick maths
                                          500 x 500 = 250,000 planar faces. 500,000 if it ends up triangulated.
                                          You should stick to 64 x 64 or below.
                                          SketchUp will eventually create a mesh of 250,000 and you'll be able to orbit fine. But the creation part will take time.
                                          • 11
                                          • 12
                                          • 13
                                          • 14
                                          • 13 / 14
