    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 476.1k Views 75 Watching
      Can you share the image you try to load?
      • E Offline
        Efrado
        Thank you for your fast answering. By the way,what do I have to do to select image clicking the right button on my mouse.
        Continuing with the attempt to install the plugin (the only one after easy install) I got this message in the skp. screen
        https://cf.dropboxstatic.com/static/images/icons/icon_spacer-vflN3BYt2.gif
        this is the bmp image:
        https://www.dropbox.com/s/qcmig0ajnkn2p5r/Screenshot%202016-04-09%2011.05.35.png?dl=0
        Thankyou
          That first image doesn't appear to load. (You can upload directly to the forum btw.)
          • E Offline
            Efrado
            Hi Thom ,sorry I am not so good with the driven of posting images. I hope this is the one
            http://i900.photobucket.com/albums/ac206/efrado47/Screenshot 2016-04-09 11.52.17_zpsdmxs46km.png
            I changed the setup of my mouse and could get the width rectangle but could not get the height
            http://i900.photobucket.com/albums/ac206/efrado47/Screenshot 2016-04-11 00.23.50_zpsort4q1xt.png
              Hmm... That message about not being supported - it would indicate you have an OSX version older than 10.7. Though that seem rather old - as it incorrectly matching your system? What is your OSX version?
              • E Offline
                Efrado
                HI Thom, this is what I have:
                http://i900.photobucket.com/albums/ac206/efrado47/Photobucket Desktop - Efrain Amado Gutierrezs MacB/Screenshot 2016-04-11 18.49.26_zpsu4tfvyro.png
                So what do I have to do in order to get your plugin works under this circumstances?
                  You have an old [now unsupported] OSX 10.6
                  As TT said, you need to have at least 10.7...
                  Can't you update your OS ?
                  There is the 'Software Update...' button on the 'About This Mac...' dialog...
                  If for some reason you can't upgrade your OS, then several Extensions [including this one] will not work...
                  That is the limitation, unless you change things...
                  Also SketchUp no longer supports v8 [and v2013 will cease shortly] - also several Extensions will no longer work in older SketchUp versions [this is often irrespective of the computer's OS, since they might rely on new API features, which are unavailable in those older SketchUp versions] - so why no 'bite-the-bullet' and upgrade both your OS and SketchUp version ?
                    I'm afraid the 10.7 requirement is because I no longer have machines to build for older systems. For every release of OSX it gets harder to support these as well as older versions. I might have to drop 10.7 soon as well given the frequency of OSX releases. πŸ˜•
                      Only thing I can think of to run 10.6 would be to try one of the older versions of TT_Lib: https://bitbucket.org/thomthom/tt-library-2/downloads
                      Though you will then have less features and bug-fixes.
                      I'm also not sure which version might be compatible.
                      • E Offline
                        Efrado
                        It is a pity.
                        Thank you Thomas, and you too Tig.
                        I will look forward to upgrade every thing.
                        Thank you again and continue with the great job for us the sketchupers.
                        • HornOxxH Offline
                          HornOxx
                          Hi All, I was just playing something around this evening
                          Some people succeed in lasering or engraving contours into a thick glass somehow - I have no idea how
                          thay do it πŸ˜„ so this little exercise, to put the author Thomas Mann in thick glass, should just imitate this nice gimmick …
                          such a great plugin - thanks for it!
                          never trust a skinny cook
                            Version 1.0.0
                            See first post for more details: https://sketchucation.com/forums/viewtopic.php?f=323&t=31339#p275772
                              Leander_Galanodel
                              Hello!
                              I just wanted to say THANK YOU for this great plugin! It saved me a lot of time. I could just import a heightmap instead of having to trace over a topographical map by hand. You saved me about a few weeks of work!
                              If I ever upload my finished "project" to the 3D-Warehouse I will put a link to this plugin in the description.
                              Thank you very much!!!
                                SpookyChick1013
                                2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:289:in each' C:/Users/Mistress Venhallyn/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:289:in trigger_event'
                                C:/Users/Mistress Venhallyn/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:250:in block in create_dialog' SketchUp:1:in call'
                                Having problems with this plugin not generating things Bitmap iin this case was 128 pixels on a side, no colorspace info, etc. Just the way it's supposed to be. I'm now stumped.
                                Thanks in advance help is greatly appreciated
                                https://kuromatsudriveyards.com
                                Fo-su to tomo ni aran koto o...
                                  How about sharing the BMP file so we can see it and maybe help you out?
                                    SpookyChick1013
                                    Thanks Dave; I would, but .bmp extensions are not allowed. (just tried to upload the bmp as an attachment) Besides, I think the problem may be something tweaked with the plugin in regard to it's interaction with SU 2017. Since I updated a few days ago, the plugin keeps trying to make a second copy of the mesh at the time when it completes the first, and throws an error.
                                    By the way, been meaning to say this for years, I like your signature.
                                      How about uploading the BMP to DropBox and sharing the link.
                                      What did you update a few days ago?
                                      Thanks on the signature.
                                        SpookyChick1013
                                        I no longer do business with Dropbox. Long story.
                                        I did solve the problem. Somehow an earlier version of the plugin got left behind when I updated it the other day. Removed it, no more problem.
                                        Thanks anyway. πŸ˜„
                                        • sketchartist023S Offline
                                          sketchartist023
                                          Think I could get a working script of this for sketchup8? I cant seem to want to update because I have a LOT of plugins that work well together already πŸ˜›
                                            I guess that thomthom's code uses Ruby API calls that are only available with newer versions of SketchUp.
                                            So looks like v8 can't hack it ! Sorry.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 13 / 14
