    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 530.7k Views 75 Watching
      That first image doesn't appear to load. (You can upload directly to the forum btw.)
      • E
        Efrado
        Hi Thom ,sorry I am not so good with the driven of posting images. I hope this is the one
        http://i900.photobucket.com/albums/ac206/efrado47/Screenshot 2016-04-09 11.52.17_zpsdmxs46km.png
        I changed the setup of my mouse and could get the width rectangle but could not get the height
        http://i900.photobucket.com/albums/ac206/efrado47/Screenshot 2016-04-11 00.23.50_zpsort4q1xt.png
          Hmm... That message about not being supported - it would indicate you have an OSX version older than 10.7. Though that seem rather old - as it incorrectly matching your system? What is your OSX version?
          • E
            Efrado
            HI Thom, this is what I have:
            http://i900.photobucket.com/albums/ac206/efrado47/Photobucket Desktop - Efrain Amado Gutierrezs MacB/Screenshot 2016-04-11 18.49.26_zpsu4tfvyro.png
            So what do I have to do in order to get your plugin works under this circumstances?
              You have an old [now unsupported] OSX 10.6
              As TT said, you need to have at least 10.7...
              Can't you update your OS ?
              There is the 'Software Update...' button on the 'About This Mac...' dialog...
              If for some reason you can't upgrade your OS, then several Extensions [including this one] will not work...
              That is the limitation, unless you change things...
              Also SketchUp no longer supports v8 [and v2013 will cease shortly] - also several Extensions will no longer work in older SketchUp versions [this is often irrespective of the computer's OS, since they might rely on new API features, which are unavailable in those older SketchUp versions] - so why no 'bite-the-bullet' and upgrade both your OS and SketchUp version ?
                I'm afraid the 10.7 requirement is because I no longer have machines to build for older systems. For every release of OSX it gets harder to support these as well as older versions. I might have to drop 10.7 soon as well given the frequency of OSX releases. πŸ˜•
                  Only thing I can think of to run 10.6 would be to try one of the older versions of TT_Lib: https://bitbucket.org/thomthom/tt-library-2/downloads
                  Though you will then have less features and bug-fixes.
                  I'm also not sure which version might be compatible.
                  • E
                    Efrado
                    It is a pity.
                    Thank you Thomas, and you too Tig.
                    I will look forward to upgrade every thing.
                    Thank you again and continue with the great job for us the sketchupers.
                    • HornOxxH
                      HornOxx
                      Hi All, I was just playing something around this evening
                      Some people succeed in lasering or engraving contours into a thick glass somehow - I have no idea how
                      thay do it πŸ˜„ so this little exercise, to put the author Thomas Mann in thick glass, should just imitate this nice gimmick …
                      such a great plugin - thanks for it!
                      never trust a skinny cook
                        Version 1.0.0
                        See first post for more details: https://sketchucation.com/forums/viewtopic.php?f=323&t=31339#p275772
                        • L
                          Leander_Galanodel
                          Hello!
                          I just wanted to say THANK YOU for this great plugin! It saved me a lot of time. I could just import a heightmap instead of having to trace over a topographical map by hand. You saved me about a few weeks of work!
                          If I ever upload my finished "project" to the 3D-Warehouse I will put a link to this plugin in the description.
                          Thank you very much!!!
                            SpookyChick1013
                            2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:289:in each' C:/Users/Mistress Venhallyn/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:289:in trigger_event'
                            C:/Users/Mistress Venhallyn/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:250:in block in create_dialog' SketchUp:1:in call'
                            Having problems with this plugin not generating things Bitmap iin this case was 128 pixels on a side, no colorspace info, etc. Just the way it's supposed to be. I'm now stumped.
                            Thanks in advance help is greatly appreciated
                            https://kuromatsudriveyards.com
                            Fo-su to tomo ni aran koto o...
                              How about sharing the BMP file so we can see it and maybe help you out?
                                SpookyChick1013
                                Thanks Dave; I would, but .bmp extensions are not allowed. (just tried to upload the bmp as an attachment) Besides, I think the problem may be something tweaked with the plugin in regard to it's interaction with SU 2017. Since I updated a few days ago, the plugin keeps trying to make a second copy of the mesh at the time when it completes the first, and throws an error.
                                By the way, been meaning to say this for years, I like your signature.
                                  How about uploading the BMP to DropBox and sharing the link.
                                  What did you update a few days ago?
                                  Thanks on the signature.
                                    SpookyChick1013
                                    I no longer do business with Dropbox. Long story.
                                    I did solve the problem. Somehow an earlier version of the plugin got left behind when I updated it the other day. Removed it, no more problem.
                                    Thanks anyway. πŸ˜„
                                    • sketchartist023S
                                      sketchartist023
                                      Think I could get a working script of this for sketchup8? I cant seem to want to update because I have a LOT of plugins that work well together already πŸ˜›
                                        I guess that thomthom's code uses Ruby API calls that are only available with newer versions of SketchUp.
                                        So looks like v8 can't hack it ! Sorry.
                                        • david_hD
                                          david_h
                                          So team: I haven't used this plugin in a while, and I may be doing something wrong. I am trying to make a mesh obviously. .. from a BMP of this image and all it does is stall out my Puter. What am I doing wrong? Something wrong iwth the image? not enough contrast?
                                          thx,
                                          p.s. I guess i could crop it to one panel and just repeat the model. Would that help?
                                            Holey buckets! There's a lot to process there. I can imagine your puter needing to take a break now and then. It would help if you can reduce the size of the image to one panel although it might still be a lot of work. It'll certainly create a lot of geometry.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 13 / 14
