    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 530.7k Views 75 Watching
      Version 1.0.0
      See first post for more details: https://sketchucation.com/forums/viewtopic.php?f=323&t=31339#p275772
      • L
        Leander_Galanodel
        Hello!
        I just wanted to say THANK YOU for this great plugin! It saved me a lot of time. I could just import a heightmap instead of having to trace over a topographical map by hand. You saved me about a few weeks of work!
        If I ever upload my finished "project" to the 3D-Warehouse I will put a link to this plugin in the description.
        Thank you very much!!!
          SpookyChick1013
          2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:289:in each' C:/Users/Mistress Venhallyn/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:289:in trigger_event'
          C:/Users/Mistress Venhallyn/AppData/Roaming/SketchUp/SketchUp 2017/SketchUp/Plugins/tt_bitmap2mesh/error_reporter/error_reporter.rb:250:in block in create_dialog' SketchUp:1:in call'
          Having problems with this plugin not generating things Bitmap iin this case was 128 pixels on a side, no colorspace info, etc. Just the way it's supposed to be. I'm now stumped.
          Thanks in advance help is greatly appreciated
          https://kuromatsudriveyards.com
          Fo-su to tomo ni aran koto o...
            How about sharing the BMP file so we can see it and maybe help you out?
              SpookyChick1013
              Thanks Dave; I would, but .bmp extensions are not allowed. (just tried to upload the bmp as an attachment) Besides, I think the problem may be something tweaked with the plugin in regard to it's interaction with SU 2017. Since I updated a few days ago, the plugin keeps trying to make a second copy of the mesh at the time when it completes the first, and throws an error.
              By the way, been meaning to say this for years, I like your signature.
                How about uploading the BMP to DropBox and sharing the link.
                What did you update a few days ago?
                Thanks on the signature.
                  SpookyChick1013
                  I no longer do business with Dropbox. Long story.
                  I did solve the problem. Somehow an earlier version of the plugin got left behind when I updated it the other day. Removed it, no more problem.
                  Thanks anyway. πŸ˜„
                  • sketchartist023S
                    sketchartist023
                    Think I could get a working script of this for sketchup8? I cant seem to want to update because I have a LOT of plugins that work well together already πŸ˜›
                      I guess that thomthom's code uses Ruby API calls that are only available with newer versions of SketchUp.
                      So looks like v8 can't hack it ! Sorry.
                      • david_hD
                        david_h
                        So team: I haven't used this plugin in a while, and I may be doing something wrong. I am trying to make a mesh obviously. .. from a BMP of this image and all it does is stall out my Puter. What am I doing wrong? Something wrong iwth the image? not enough contrast?
                        thx,
                        p.s. I guess i could crop it to one panel and just repeat the model. Would that help?
                          Holey buckets! There's a lot to process there. I can imagine your puter needing to take a break now and then. It would help if you can reduce the size of the image to one panel although it might still be a lot of work. It'll certainly create a lot of geometry.
                          • david_hD
                            david_h
                            So i discovered. I got it to work with one panel, but the results were underwhelming. I think I will just use the image and a call it a day. 😲
                            Holy Buckets??? πŸ’š
                              Probably a good idea to use the image as a texture. Reminds me of the curtain slides that would show during intermissions in the old black and white films.
                              Holey if the water won't stay in. πŸ˜‰
                              • david_hD
                                david_h
                                The texture is fine, using Photoshop of course. i was just playing to see if I could get it to work in 3D
                                Thx,
                                D
                                There's a hole in the bucket. . .dear Liza.. .dear Liza. . .
                                • T
                                  Triumfi
                                  The arrows for reducing pixels or polygons does not show, when i bring the cursor to the red line, any idea ??
                                    rayqian
                                    this is a great plugin for customize tiling texture, while the sketchup has no responding when I import a 500*500 pixel test BMP file as an image and run "mesh from bitmap", see the screenshot.
                                      Quick maths
                                      500 x 500 = 250,000 planar faces. 500,000 if it ends up triangulated.
                                      You should stick to 64 x 64 or below.
                                      SketchUp will eventually create a mesh of 250,000 and you'll be able to orbit fine. But the creation part will take time.
                                      • 11
                                      • 12
                                      • 13
                                      • 14
                                      • 13 / 14
