    [Plugin] Bitmap To Mesh
    264 Posts 75 Posters 508.1k Views 75 Watching
      How about sharing the BMP file so we can see it and maybe help you out?
        SpookyChick1013
        Thanks Dave; I would, but .bmp extensions are not allowed. (just tried to upload the bmp as an attachment) Besides, I think the problem may be something tweaked with the plugin in regard to it's interaction with SU 2017. Since I updated a few days ago, the plugin keeps trying to make a second copy of the mesh at the time when it completes the first, and throws an error.
        By the way, been meaning to say this for years, I like your signature.
        https://kuromatsudriveyards.com
        Fo-su to tomo ni aran koto o...
          How about uploading the BMP to DropBox and sharing the link.
          What did you update a few days ago?
          Thanks on the signature.
            SpookyChick1013
            I no longer do business with Dropbox. Long story.
            I did solve the problem. Somehow an earlier version of the plugin got left behind when I updated it the other day. Removed it, no more problem.
            Thanks anyway. πŸ˜„
            • sketchartist023S Offline
              sketchartist023
              Think I could get a working script of this for sketchup8? I cant seem to want to update because I have a LOT of plugins that work well together already πŸ˜›
                I guess that thomthom's code uses Ruby API calls that are only available with newer versions of SketchUp.
                So looks like v8 can't hack it ! Sorry.
                • david_hD Offline
                  david_h
                  So team: I haven't used this plugin in a while, and I may be doing something wrong. I am trying to make a mesh obviously. .. from a BMP of this image and all it does is stall out my Puter. What am I doing wrong? Something wrong iwth the image? not enough contrast?
                  thx,
                  p.s. I guess i could crop it to one panel and just repeat the model. Would that help?
                    Holey buckets! There's a lot to process there. I can imagine your puter needing to take a break now and then. It would help if you can reduce the size of the image to one panel although it might still be a lot of work. It'll certainly create a lot of geometry.
                    • david_hD Offline
                      david_h
                      So i discovered. I got it to work with one panel, but the results were underwhelming. I think I will just use the image and a call it a day. 😲
                      Holy Buckets??? πŸ’š
                        Probably a good idea to use the image as a texture. Reminds me of the curtain slides that would show during intermissions in the old black and white films.
                        Holey if the water won't stay in. πŸ˜‰
                        • david_hD Offline
                          david_h
                          The texture is fine, using Photoshop of course. i was just playing to see if I could get it to work in 3D
                          Thx,
                          D
                          There's a hole in the bucket. . .dear Liza.. .dear Liza. . .
                            Triumfi
                            The arrows for reducing pixels or polygons does not show, when i bring the cursor to the red line, any idea ??
                              rayqian
                              this is a great plugin for customize tiling texture, while the sketchup has no responding when I import a 500*500 pixel test BMP file as an image and run "mesh from bitmap", see the screenshot.
                                Quick maths
                                500 x 500 = 250,000 planar faces. 500,000 if it ends up triangulated.
                                You should stick to 64 x 64 or below.
                                SketchUp will eventually create a mesh of 250,000 and you'll be able to orbit fine. But the creation part will take time.
                                • 11
                                • 12
                                • 13
                                • 14
                                • 13 / 14
