    Animator Gallery
    renderpluginsextensions
    106 Posts 30 Posters 486.7k Views 30 Watching
      Treadshot A1
      More testing with Animator v1.5b and trial Thea. I have no idea what Thea is doing, to be honest. At least every group moves back to its intended position right as its first unit movement starts. Also, once a group does have a unit movement applied to it, after that movement, it doesn't move about unexpectedly anymore.
      Animator tested on [SU8Free Win8] and [SU8Free Win10]. Rendering achieved with Thea calling Animator, Thea settings [IR-Presto (AO) Interactive unchecked, 16 samples/px], rendered on [SU8Free Win10].
      Model: Trinity by Treadshot A1
      Fine print: As per trial version of Thea, Thea rendered video is set to Unlisted, uploaded solely for purpose of reporting results of beta test, and will NOT be used when Trinity is released to public. Natural Rendering video will be used for public release of Trinity, as it does not use Thea.
      Natural Rendering (Animator only)
      Thea Rendering
      Glitches: Lots of things move. Not the way they should move, unfortunately.
      Notes: Video length doesn't match, because the Thea video was made with Blender, at 24fps, while images were rendered at 25fps. Not a major concern.
      Attempted more testing with Thea and Animator v1.5b, with new Animator files native to v1.5b (previous examples used Animator files created in v1.4). I'm not seeing the above glitches, but it's only one animation I've done so far, so I cannot say if the unexpected movements are the result of using old Animator files or not.
      Model: Data Minion Eagle by Treadshot A1
      Fine print: As per trial version of Thea, Thea rendered video is set to Unlisted, uploaded solely for purpose of reporting results of beta test, and will NOT be used when Data Minion Eagle is released to public. Natural Rendering video will be used for public release of Data Minion Eagle, as it does not use Thea.
      Thea Rendering
      EDIT: I am completely wrong. Files native to v1.5b can still have parts moving randomly. I tried adding an extra section to the animation of Data Minion Eagle above. A few unit movements were affected (a translation of 10mm in x direction is followed by a translation of -10mm in x direction later; for some reason the part ends up slightly shifted in the y direction, which had to be corrected with an additional movement). It looked fine in Animator, but Thea doesn't seem to match it.
      I will note that in the process of rendering the animation, either Thea or Animator went haywire; I was put back into Sketchup's interface, but Animator's actions were accessible through Sketchup's Undo (pressing CTRL+Z would show the groups as they were moved in Animator, but actually moved in the sketchup model file). I couldn't get a screenshot of it; I had to close Sketchup and open a backup copy of my model/animation. I have no idea how that happened. The rendered animation below is a second attempt at rendering.
        Treadshot A1
        Found a workaround with Animator and Thea rendering. Used to experience random movements of groups/components when rendering with Thea, which did not happen when rendering video with Animator's Natural rendering option. For instance, if a component rotates at 16.5s, anytime from 0-16.4s the component's position could not be relied upon, but 16.5s and onward the animation works fine (see: Data Minion Jaguar animation, a few posts up from this one). Solution: In Sketchup, place all objects in one large group, then apply an unnoticeable Unit Movement to that group at 0.0s in the timeline. In the test case below, I've used [move along Z-axis 0.1mm].
        Test animation, Natural:
        Test animation, Thea:
        //SU8Free, Win8, Animator v1.5d, Trial Thea, Natural video rendered from Animator, Thea video Rendered using Animation setting in Thea Render window (Thea calls Animator).
          Lavanta
          Thank you for posting so many videos on your projects! Really appreciate that. Especially for me as an amateur it's nice to see how other do their stuff πŸ˜„
          • chriC Offline
            chri
            Thanks Fredo
            The Movement Along Path fonction is marvellous and easy to used.
            Very great job and major improvement for SKETCHUP animation.
            πŸ‘ πŸ‘ πŸ‘
              Charlie__V
              Experimenting......maybe an apple on head would entice..........
              best regards,
              Charlie
              Edit: Still experimenting....revised .gif attached
              Bow/Arrow
              Bow/Arrow Rev1
              • ithilI Offline
                ithil
                Hello. This is my test of the escalator animation.
                I made a shift to the size of one step. And he turned on the replay.youtube
                I tried using animation on the way but there were problems.
                • jiminy-billy-bobJ Offline
                  jiminy-billy-bob
                  Neat!
                  • fredo6F Offline
                    Very clever solution for something which is not obvious to animate a priori.
                    I watched your 'making-of' video. What kind of issues did you encounter?
                    • renderizaR Offline
                      renderiza
                      I am very interested in this Animator Extension!
                      The following .gif is my first animation done with Animator...
                      https://s20.postimg.org/f87v2o6st/300-i_Select-anim-2.gif
                      Keep up the great work!
                      Best Regards,
                      Renderiza
                      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                      • JQLJ Offline
                        JQL
                        Where have you been Renderiza? I'm still using your stylish plugins, specially rename by layer...
                        Keep up the good work Fredo!
                        www.casca.pt
                        Visit us on facebook!
                          renderiza
                          Very nice to see you again as well! I've been busy with live but now I get to enjoy SketchUp once more, and I'll update my old, old.....OLD extensions little by little.
                          Best regards,
                          Renderiza
                          • MANaboutTOOLSM Offline
                            MANaboutTOOLS
                            I used Animator in my latest YouTube video. See the section that starts at 0:17 seconds. It's a Timber Frame Pavilion model that I created in Sketchup and animated with Fredo's Animator plugin on my Mac. I used Final Cut Pro to add titles and to change the speed in some sections and for dissolves/fades in some places. I rendered all the sequences at 60 fps so they would be very smooth before importing into Final Cut where the video output is 24 fps. I rendered and edited everything at 4K resolution. I didn't use any rendering software as I don't think any of them support GPU rendering on a Mac.
                            • ntxdaveN Offline
                              ntxdave
                              Very well done πŸ‘
                              The quality of the video was very good. There was good use of Animator as well as a good interaction between the drawing and the development of the finished product.
                              Press F1...thank me later
                                Tallkoala
                                Here is my first project using animator. Thanks Fredo for making this excellent and easy to use plugin...
                                • ntxdaveN Offline
                                  ntxdave
                                  The animation is well done. Now you need to use some rendering software to "bring it to life". πŸ‘
                                  Animator supports several rendering software packages.
                                  • HornOxxH Offline
                                    HornOxx
                                    πŸ‘ πŸ‘ πŸ˜„ a wonderful work Renderiza! - I especially like this graphically reduced style which you have achieved as result. It's remarkable how important this little detail is, that this little black guy next to the fireplace blinks sporadically. Really really nice and I enjoyed it a lot!
                                    never trust a skinny cook
                                      renderiza
                                      Hi, my name is Rafael Rivera and apart from developing SketchUp extensions, I want to also start making games. Here is me exploring possible art style for the game.
                                      I used Fredo’s Animator SketchUp plugin for animating this stylized environment. The only thing made in post-production was the fire which I used Pixel FX Designer. I then used ScreenFlow 8 to capture my SketchUp screen and exported the final edit with sound & music. The music is titled β€˜Scared Happy’ and was composed by myself as well.
                                      Everything is modeled with Quads so I used Thomthom’s Vertex Tools 2 and SubD. Also, used Artisan by mind.sight.studios to smooth selection a lot.
                                      More extensions were used but I’ll share them another day.
                                      https://aws1.discourse-cdn.com/sketchup/optimized/3X/e/c/ec826211fe40a0e4a5daffd56c28831724bdf156_2_998x1000.png
                                      Everything is colored with SketchUp color material with no textures.
                                      https://aws1.discourse-cdn.com/sketchup/optimized/3X/f/a/faa326c89eeea73c663183a6c9038eee6899f422_2_998x1000.png
                                      Hope everyone enjoys my animation with SketchUp!
                                      #sketchup #animation #animator
                                      • fredo6F Offline
                                        @renderiza
                                        Very artistic usage of Animator. Bravo!
                                        PS: you could have moved the clouds too...
                                          Poetic! 😎
                                          • Bryan KB Offline
                                            Love everyone's animations. I hope to tackle this next. I have the plug in, just need to get inspired.
                                            Fredo6, you rock! All of your plug-ins are amazing! I wish I were rich so I could pay you what you deserve. πŸ‘
                                            • 5 / 6
