    Animator Gallery
    renderpluginsextensions
    106 Posts 30 Posters 486.7k Views 30 Watching
      Unreal is some more difficult than Unity! πŸ˜‰
      • JQLJ Offline
        JQL
        I've seen nicer images from Unreal than Unity. Basically, lighting is better. However I've heard something about Unity having revamped their lighting... Why is it easier?
        www.casca.pt
        Visit us on facebook!
        • ntxdaveN Offline
          ntxdave
          @rich o brien said:
          No point. The image sequence plays in the viewport so it would not sync with the frame rate.
          Only direct viewport recording would work.
          So, are you saying this would not work with Animator or was you animation generated with Animator?
          Press F1...thank me later
            I'm saying to only way to capture the animated texture is to record the viewport.
            Exporting the animation won't export the animation applied with SKMtools.
            • ntxdaveN Offline
              ntxdave
              That is what I thought you were saying. What did you use to create the animated gif?
                It's not a gif. It's an image sequence of pngs.
                If you google fire image sequence you get a result for them at opengameart
                You could even try for water spray to see if you can find something for your car wash
                  S1919
                  RHas any one worked with Maxwell Render and this plugin?
                  Would be great to hear the workflow!
                  • fredo6F Offline
                    I does not how how to contact Maxwell developers. So today, it is not interfaced with it.
                      M3one
                      This is what I've been doing lately.
                      Thanks for the development
                      • ntxdaveN Offline
                        ntxdave
                        Nice animation. The sound affect adds a lot to it. πŸ˜„
                          Treadshot A1
                          Made this animation to illustrate how an action figure of mine transforms. Haven't got it properly rendered yet, but it works.
                          For reference, the action figure is Trinity.
                            That's fab!
                              What a transformer! 😎
                              • fredo6F Offline
                                Impressive work, both the model and the design of the animation for so many objects!
                                • chriC Offline
                                  chri
                                  @ithil said:
                                  Hi.
                                  My test animation.
                                  Beautiful explanation.
                                  Any complex assembly should be explained like this.
                                  So now,I wonder if I will not build a fireplace πŸ’š
                                  Chri
                                  • ithilI Offline
                                    ithil
                                    Hi.
                                    My test animation.
                                    This instruction for installation concrete build-up fireplace
                                    PS. How I can make export a higher resolution?
                                    I was not able to export more than 1030 pixels.
                                    Usually I make a SketchUp render double the larger than needed for the video.
                                    And reduce it in the video editor. To achieve a good antialiasing
                                    https://youtu.be/qSyt4vN94VA
                                      shahram67
                                      @fredo6 said:
                                      I would suggest that you, dear beta testers, post (almost) finished animations under this thread (as YouTube videos).
                                      hi all
                                      this is my first animation in sketchup , i make it with animator plugin in sketchup, work by this plugin is very simple ,Making this animation an hour, I thank fredo6
                                      • fredo6F Offline
                                        Well done. really!
                                        I may be interested by the model at some point in time, because of the hydraulic piston. Actually, this is a good sample case for more sophisticated kinematics constraints.
                                          Treadshot A1
                                          Here's the result of my testing with Animator v1.5b and trial Thea. Animator tested on [SU8Free Win8] and [SU8Free Win10]. Rendering achieved with Thea calling Animator, Thea settings [IR-Presto (AO) Interactive unchecked, 16 samples/px], rendered on [SU8Free Win10].
                                          Model: Data Minion Jaguar by Treadshot A1
                                          Fine print: As per trial version of Thea, Thea rendered video is set to Unlisted, uploaded solely for purpose of reporting results of beta test, and will NOT be used when Data Minion Jaguar is released to public. Natural Rendering video will be used for public release of Data Minion Jaguar, as it does not use Thea.
                                          Natural Rendering (Animator only)
                                          Thea Rendering
                                          Glitches: "Tail" part should rotate starting at 16.5 seconds. No other movements applied to "Tail", no movements referencing "Tail" geometry, "Tail" group is separate from all other components and NOT nested in any other group. Animated correctly with Natural settings; "Tail" unexpectedly moves down then snaps back into place when animated by Thea. *Note: Tail moves 180deg in Natural video, 165deg in Thea as result of trying to fix movement, angle rotated is not an error.
                                          • ntxdaveN Offline
                                            ntxdave
                                            I like them. Obviously not you first animation. Looking forward to your next animation post.
                                            • 4 / 6
